查看: 1979|回复: 1
[求助] channel的size默认的是1吗?怎么修改channel的size?
发表于 2014-4-26 10:02:11 | 显示全部楼层 |阅读模式
发表于 2014-4-28 16:48:37 | 显示全部楼层
vmm_channel
function new( string name, string inst, int    full = 1, int    empty = 0, bit    fill_as_bytes = 0);
full specifies the FIFO depth. empty specifies minimum bounds on the FIFO.  fill_as_bytes
specifies if FIFO level is based on number of transactions or number of bytes.
GMT+8, 2025-12-20 04:16 , Processed in 0.012127 second(s), 4 queries , Gzip On, Redis On.
