查看: 1731|回复: 0
[招聘] 【南京】Marvell诚招Physical design engineer
发表于 2014-4-25 14:29:25 | 显示全部楼层 |阅读模式
JobTitle:
Physical Design Engineer
Responsibilities:
As member of Marvell central physicaldesign team, you will play a challenging role in assisting multiple Marvelldesign groups in sign-off check includes power/signal integrity analysis (IRdrop, EM, ESD), physical verification (DRC/LVS/ERC/Antenna), chip-level layoutand tapeout, as well as maintaining power analysis and physical verificationflow, custom layout and add-on tools.
Requirements:
o     2+years of direct experience on IC design. BS/MS preferred.
o     Knowledgein some of the following technical areas: custom layout, PCB layout, powerconsumption calculate, timing, chip package.
o     Proventrack records of working independently on running and debugging chip-levelDRC/LVS/ERC/Antenna results.
o     Understandingof power planning, be able to analyze the weakness of power grid and providesolution.
o     BeFamiliar with Laker, Cadence Virtuoso, or Mentor DesignRev. Strong knowledge todebug Mentor’s Calibre or Synopsys’ Hercules tools.
o     Befamiliar with Apache, Encounter Power System, or PrimeRail.
o     Mustbe programming-minded, capable of writing Tcl or Perl.
o     Self-motivatedteam worker, good verbal and written communication skills.
o     Knowledgeof Cadence or Synopsys Place and Route tools a big plus.
o     Mustable to work under tapeout pressure and tight schedule.
GMT+8, 2025-12-25 21:08 , Processed in 0.013669 second(s), 6 queries , Gzip On, Redis On.
