查看: 9383|回复: 12
[求助] 关于UVM中一个警告的疑问
发表于 2014-4-24 16:14:36 | 显示全部楼层 |阅读模式
# UVM_WARNING @ 0: uvm_test_top.env [UVM_DEPRECATED] build()/build_phase() has been called explicitly, outside of the phasing system. This usage of build is deprecated and may lead to unexpected behavior.
# UVM_WARNING @ 0: uvm_test_top [UVM_DEPRECATED] build()/build_phase() has been called explicitly, outside of the phasing system. This usage of build is deprecated and may lead to unexpected behavior.
环境:qustasim 10.2c win64,UVM_1.1d
想问一下这个是什么问题导致的警告?谢谢
 楼主| 发表于 2014-4-24 16:33:07 | 显示全部楼层
回复 1# guolehaohao
   已经找到解决方法...
发表于 2014-9-2 10:47:01 | 显示全部楼层
回复 2# guolehaohao
   请问是如何解决的,我现在也遇到了同样的问题啊,求帮助
发表于 2014-9-3 13:59:15 | 显示全部楼层
回复 3# xiangeryong333
不要显式调用build_phase就没事,UVM不推荐这么做
发表于 2014-9-3 20:32:06 | 显示全部楼层
回复 4# seabeam
   一般不都是在某个类定义build_phase(uvm_phase phase)中调用吗?如:super.build_phase(phase);
发表于 2014-9-4 10:32:02 | 显示全部楼层
super没有关系,不要直接build_phase就行。取决于m_phasing_active的值是不是0
有兴趣参考1.1d
./base/uvm_component.svh:2269
以及uvm_topdown_phase的traverse()
发表于 2014-9-5 10:36:30 | 显示全部楼层
回复 6# seabeam
   好的,多谢指教
发表于 2014-9-5 10:47:46 | 显示全部楼层
回复 6# seabeam
   q请问你有见过这样的warning吗?
374 UVM_WARNING /opt/cadence/INCISIV132/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1436)          @ 0.0 ns: uvm_test_top.sve.regular_env.arbiter.sequencer [UVM_DEPRECATED] Registering sequence 'uvm_random         _sequence' with sequencer 'uvm_test_top.sve.regular_env.arbiter.sequencer' is deprecated.
     375 UVM_WARNING /opt/cadence/INCISIV132/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1436)          @ 0.0 ns: uvm_test_top.sve.regular_env.arbiter.sequencer [UVM_DEPRECATED] Registering sequence 'uvm_exhaus         tive_sequence' with sequencer 'uvm_test_top.sve.regular_env.arbiter.sequencer' is deprecated.
     376 UVM_WARNING /opt/cadence/INCISIV132/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1436)          @ 0.0 ns: uvm_test_top.sve.regular_env.arbiter.sequencer [UVM_DEPRECATED] Registering sequence 'uvm_simple         _sequence' with sequencer 'uvm_test_top.sve.regular_env.arbiter.sequencer' is deprecated.
1349 UVM_WARNING /opt/cadence/INCISIV132/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1520)          @ 0.0 ns: uvm_test_top.sve.regular_env.slaves[0].sequencer [UVM_DEPRECATED] Starting (deprecated) default          sequence 'vr_ahb_slave_default_seq' on sequencer 'uvm_test_top.sve.regular_env.slaves[0].sequencer'. See do         cumentation for uvm_sequencer_base::start_phase_sequence() for information on starting default sequences in          UVM.
    1350 UVM_WARNING /opt/cadence/INCISIV132/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1520)          @ 0.0 ns: uvm_test_top.sve.regular_env.masters[0].sequencer [UVM_DEPRECATED] Starting (deprecated) default          sequence 'vr_ahb_master_random_seq' on sequencer 'uvm_test_top.sve.regular_env.masters[0].sequencer'. See          documentation for uvm_sequencer_base::start_phase_sequence() for information on starting default sequences          in UVM.
    1351 UVM_WARNING /opt/cadence/INCISIV132/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1520)          @ 0.0 ns: uvm_test_top.sve.regular_env.arbiter.sequencer [UVM_DEPRECATED] Starting (deprecated) default se         quence 'vr_ahb_arbiter_default_seq' on sequencer 'uvm_test_top.sve.regular_env.arbiter.sequencer'. See docu         mentation for uvm_sequencer_base::start_phase_sequence() for information on starting default sequences in U         VM.
是提示我的sequencer和sequence有问题吗?还是只是个warning?
发表于 2014-9-9 10:10:04 | 显示全部楼层
回复 8# xiangeryong333
不知道你是不是用了uvm_update_sequence_lib类似的宏
发表于 2014-9-9 15:05:25 | 显示全部楼层
回复 9# seabeam
   没有用uvm_update_sequence宏没有用,但是其他一些宏倒是用到过,如:uvm_sequence_utils, uvm_rand_send, uvm_field_object等一些宏,这些会有什么影响吗?
GMT+8, 2025-12-19 13:41 , Processed in 0.020344 second(s), 3 queries , Gzip On, Redis On.
