查看: 2133|回复: 2
[求助] MODELSIM仿真遇到的问题
发表于 2014-4-22 18:49:40 | 显示全部楼层 |阅读模式
这是移位运算的一段代码,但是结果输出的时候,F3能够正常输出,CY2却输不出来,求大神帮帮忙
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY SHIFTER IS
  PORT(S: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
  DATAA, DATAB: IN STD_LOGIC_VECTOR(7 DOWNTO 0);
  F3: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
  FC, CN: IN STD_LOGIC;
  CY2: OUT STD_LOGIC);
END SHIFTER;
ARCHITECTURE SHIFTER OF SHIFTER IS
  BEGIN
    PROCESS(S, DATAB)
    VARIABLE  TEMP : INTEGER range 0 to 255;
    VARIABLE  I : INTEGER range 0 to 7;
    BEGIN
    TEMP := 0;
    I:=7;
    FOR I IN 0 to 7 LOOP
      CASE DATAB(I) IS
      WHEN '0' => TEMP:=TEMP;
      WHEN '1' => TEMP:=TEMP+2**I;
      WHEN OTHERS =>EXIT;
      END CASE;
    END LOOP;
    CASE S(2 DOWNTO 0) IS
    WHEN "101" => F3<=DATAA((TEMP MOD 8 -1) DOWNTO 0) &  DATAA(7 DOWNTO (TEMP MOD 8));
    WHEN "110" =>
    IF(CN = '0') THEN
      F3<= '0' & DATAA(7 DOWNTO 1);
    ELSIF(CN = '1') THEN
       CY2 <= DATAA(0);
    ELSE
      F3<=(OTHERS=>'Z');
    END IF;
    WHEN "111" =>
    IF(CN = '0') THEN
      F3<=  DATAA(6 DOWNTO 0) & '0';
     CY2 <= DATAA(7);
    ELSE
      F3<=(OTHERS=>'Z');
    END IF;
    WHEN OTHERS => F3<=(OTHERS=>'Z');
    END CASE;
END PROCESS;
END SHIFTER;
 楼主| 发表于 2014-4-22 19:54:36 | 显示全部楼层
自己顶
发表于 2014-4-23 03:31:34 | 显示全部楼层
帮忙顶
GMT+8, 2025-12-27 00:13 , Processed in 0.016650 second(s), 5 queries , Gzip On, Redis On.
