查看: 4155|回复: 6
[求助] Virtuoso Analog Design Environment X ToolKit Error
发表于 2014-4-22 15:15:08 | 显示全部楼层 |阅读模式
悬赏300资产未解决
求助各位大侠:在我试图关闭IC5141中的Analog Design Environment窗口时,整个CIW窗口会一并退出,并在CDS.log中报如下错误信息:X Toolkit Error: Object "(null)" does not have windowed ancestor.
折腾了两三天,实在没头绪,请问哪位有建议?十分感谢!
 楼主| 发表于 2014-4-22 16:10:24 | 显示全部楼层
哪位大侠不吝赐教,十分感谢!
发表于 2014-4-22 16:42:25 | 显示全部楼层
感觉是系统的问题,可能是有补丁没有安装。
用   IC51/tools/bin/checkSysConf IC5.1 命令看看有什么fail的补丁,然后按要求安装。
 楼主| 发表于 2014-4-23 08:39:51 | 显示全部楼层
回复 3# question23
命令返回消息:
  1. =====================================================================[Copyright 2002-2011] Cadence Design Systems, Inc. All rights reserved.
  2. This  program and online  documentation  may not be copied, modified,re-published, uploaded,  executed, or  distributed in any way, in anymedium, whether in whole or in part, without prior written permissionfrom Cadence Design Systems, Inc.=====================================================================
  3. ============== checkSysConf:  Version 3.19 ====================
  4. Configuration checks failed on this workstation (T50), status is: FAIL
  5. The specified software release 'IC5.1' is not supportedfor your platform / OS (x86_64 / )Type checkSysConf -r to see the current versions
  6. Exiting checkSysConf ... Good-byeOutput is saved as /tmp/checkSysConf.T50-2014.04.23.08:36.8201.log
    复制代码
我的IC版本是5.10.41.500.6.151,请问“prudctID”是什么字符?谢谢!
发表于 2014-4-23 14:39:35 | 显示全部楼层
回复 4# ralphzheng
    checkSysConf -r
看看输出什么
发表于 2016-4-19 15:08:01 | 显示全部楼层
da shen ,zui hou zen me jie jue de ?  xiexie!
发表于 2018-7-4 22:40:00 | 显示全部楼层
回复 1# ralphzheng
    Hi,请问是怎么解决的?
GMT+8, 2025-12-18 18:42 , Processed in 0.017763 second(s), 4 queries , Gzip On, Redis On.
