楼主 |
发表于 2014-4-19 06:29:54
显示全部楼层
回复 2# huiyuanai3
多谢大侠回帖。
我用Core generator 生成了一个BRAM.xco 文件,然后在同一个project里试图用一个叫TopBRAM.v的文件来例化我刚生成的BRAM。
为了简单处理,我在TopBRAM.v中没有做任何操作,只是试图例化BRAM:
module TopBRAM(clk, leds
input clk;
output [7:0] leds;
wire wea;
wire [9:0] addra;
wire [7:0] dina;
wire clk;
wire ena;
BRAM mybram(.wea(wea), .addra(addra), .dina(dina), .clka(clk), .ena(ena));
endmodule
结果得到以下错误信息,请问大侠我还有那些操作没有考虑到?
WARNING:HDLCompiler:1016 - "C:\Xilinx\DesignFiles\IPBRAM\TopBRAM.v" Line 30: Port douta is not connected to this instance
WARNING:HDLCompiler:1499 - "C:\Xilinx\DesignFiles\IPBRAM\ipcore_dir\BRAM.v" Line 39: Empty module <BRAM> remains a black box.
WARNING:HDLCompiler:634 - "C:\Xilinx\DesignFiles\IPBRAM\TopBRAM.v" Line 25: Net <wea> does not have a driver.
WARNING:HDLCompiler:634 - "C:\Xilinx\DesignFiles\IPBRAM\TopBRAM.v" Line 26: Net <addra[9]> does not have a driver.
WARNING:HDLCompiler:634 - "C:\Xilinx\DesignFiles\IPBRAM\TopBRAM.v" Line 27: Net <dina[7]> does not have a driver.
WARNING:HDLCompiler:634 - "C:\Xilinx\DesignFiles\IPBRAM\TopBRAM.v" Line 29: Net <ena> does not have a driver.
WARNING:Xst:653 - Signal <addra> is used but never assigned. This sourceless signal will be automatically connected to value GND.
WARNING:Xst:653 - Signal <dina> is used but never assigned. This sourceless signal will be automatically connected to value GND.
WARNING:Xst:653 - Signal <wea> is used but never assigned. This sourceless signal will be automatically connected to value GND.
WARNING:Xst:653 - Signal <ena> is used but never assigned. This sourceless signal will be automatically connected to value GND.
WARNING:Xst:1814 - Core <BRAM.ngc> does not contain any logic. |
