查看: 3750|回复: 3
[求助] abstract提取macro单元的lef文件,extract步骤出错
发表于 2014-4-15 16:41:17 | 显示全部楼层 |阅读模式
用abstract提取一个SRAM的lef文件时候,在进行到extract步骤时,出现了很多这样的
warning:The Abstract was unable to calculate process antenna values for net DATAOUT_IN<7> because no polysilicon was extracted.check the layer connectivity for the net in question and run the step again  if the problem persist ,click the message ID for more information .
上面的DATAOUT<7>是单元中的一个名字,所有的PIN名字都提到 了这个warning。下面的这个图我是extract步骤中的各个选项
请问这是怎么个情况?谢谢!
 楼主| 发表于 2014-4-15 16:53:16 | 显示全部楼层
发表于 2014-4-16 09:15:59 | 显示全部楼层
Maybe transfer symbol <> to [] being working.
 楼主| 发表于 2014-4-16 11:09:48 | 显示全部楼层
回复 3# d09ee2612
the schematic use <> ,but thanks ,i will try
GMT+8, 2025-12-30 00:29 , Processed in 0.019969 second(s), 7 queries , Gzip On, Redis On.
