查看: 2974|回复: 3
求救:改了环境变量后不能登录系统了
发表于 2014-4-12 09:50:48 | 显示全部楼层 |阅读模式
唉,搞了一天总算是把软件装上去了,但改了环境变量后重启不能登录系统了,肯定是环境变量改得有问题,大神们帮我看看吧,昨晚搞到凌晨3点实在是顶不住了
QQ截图20140412095219.jpg 就是这在里不管用什么账号都登录不了,输入完密码确定后过屏幕一黑又回来这里了
#################### Synopsys EDA ####################
# Home
export synopsys=/home/eda/synopsys
export scl=/home/eda/synopsys/synopsys/scl
export sentaurus=/home/eda/synopsys/sentaurus
# License
/home/eda/synopsys/scl/amd64/bin/lmgrd -c /home/eda/synopsys/scl/admin/license/license.dat  -l /home/eda/synopsys/scl/admin/logs/license.log
export LM_LICENSE_FILE=/home/eda/synopsys/scl/admin/license/license.dat
export PATH=/home/eda/synopsys/scl/amd64/bin
# Sentaurus H-2013.03
export STROOT=/home/eda/synopsys/sentaurus
export PATH=/home/eda/synopsys/sentaurus/bin
export STDB=/home/eda/synopsys/sentaurus
 楼主| 发表于 2014-4-12 12:58:17 | 显示全部楼层
请问下大家,我刚把别人的bashrc改完进系统运行swb 提示这些:
[eda@cad       ]$ swb
License lookup failed: Cannot connect to license server system.
  The license server manager (lmgrd) has not been started yet,
  the wrong port@host or license file is being used, or the
  port or hostname in the license file has been changed.
Feature:       swb_all
Server name:   cad
License path:  27000@cad
FLEXnet Licensing error:-15,570.  System Error: 115 "Operation now in progress"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2013.03"
        * STROOT is "/home/eda/synopsys/sentaurus/bin/.."
        * hostname is "cad"
        * display is "/dev/pts/0"
        * user is "eda"
我把hosts里面加入了我的主机名 cad啊,怎么还会这样
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4 cad
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6 cad
发表于 2015-1-8 19:59:06 | 显示全部楼层
回复 2# luwei370
   请问你解决了吗?我也出现这个问题
发表于 2016-7-5 23:29:39 | 显示全部楼层
Thanks.......
GMT+8, 2025-12-23 09:42 , Processed in 0.021206 second(s), 7 queries , Gzip On, Redis On.
