楼主: snk88
ads2014.01 linux patch+systemvue2013.08 patch
发表于 2014-8-31 20:58:58 | 显示全部楼层
和136楼的错误一样
发表于 2014-9-7 10:40:05 | 显示全部楼层
RE: ads2014.01 linux patch+systemvue2013.08 patch
发表于 2014-9-7 23:42:48 | 显示全部楼层
谢谢啊
发表于 2014-9-10 22:48:53 | 显示全部楼层
谢谢楼主
发表于 2014-9-13 14:57:18 | 显示全部楼层
回复 1# snk88
f it is real , that gonna be end of me....
发表于 2014-9-13 14:57:56 | 显示全部楼层
回复 171# wvin
和137楼的错误一样
发表于 2014-9-19 14:14:43 | 显示全部楼层
Greate software
发表于 2014-9-21 22:20:42 | 显示全部楼层
xie xie
发表于 2014-9-24 15:10:39 | 显示全部楼层
試試下,謝謝囉
发表于 2014-9-24 21:34:35 | 显示全部楼层
FYI:  It works great for me with this Linux OS:   KUBUNTU 12.04
I had just the issue: Cannot mix incompatible Qt library (version ....cut   ,   which was solved by adding the following in the environment file:
export QTDIR=""
export LD_LIBRARY_PATH=""
export QT_PLUGIN_PATH=""
export KDEDIRS=""
export KDEDIR=""
GMT+8, 2025-12-23 05:44 , Processed in 0.019241 second(s), 4 queries , Gzip On, Redis On.
