楼主: snk88
ads2014.01 linux patch+systemvue2013.08 patch
发表于 2014-5-11 01:31:37 | 显示全部楼层
Awesome post!
However, I get the following error when try to run simulation on momentum. Any idea?
"Error: failed to install result files from the input/output directory."
I believe, I'm missing some library or dependency, but don't know how to find it out. No clue.
发表于 2014-5-12 21:30:06 | 显示全部楼层
感谢,好东西
发表于 2014-5-13 16:42:46 | 显示全部楼层
回复 110# chris2013
   Thanks for your help.Each problem can be fixed by installing RPM which ADS needs to run.
发表于 2014-5-14 22:43:31 | 显示全部楼层
回复 1# snk88
一个好人!!!
发表于 2014-5-18 00:13:57 | 显示全部楼层
回复 1# snk88
您太强大了!随心所欲,信手拈来between Windows and Linux.
发表于 2014-5-18 16:19:35 | 显示全部楼层
多谢楼主
发表于 2014-5-18 21:16:12 | 显示全部楼层
破解systemvue , 提示 无法定位输入点,失败
 楼主| 发表于 2014-5-18 22:45:25 | 显示全部楼层
回复 117# merit_ww
   for 64bit.
发表于 2014-5-18 23:15:09 | 显示全部楼层
gooooooooooooooooooooooood
发表于 2014-5-19 17:13:50 | 显示全部楼层
Guys
i have problem with installing this software
Any one who installed successfully this software please re upload the corrected ADSPATCH and the correct license file
thanks alot.
GMT+8, 2025-11-7 20:13 , Processed in 0.935557 second(s), 3 queries , Gzip On, Redis On.
