查看: 3005|回复: 0
[招聘] 美资外企招聘:数字IC设计/验证/模拟/信号处理,上海张江,新开张,速来
发表于 2014-4-9 12:39:16 | 显示全部楼层 |阅读模式
1. Digital RTL Design and Implementation (synthesis \ DFT \ Timing Closure) Engineer
Responsibilities
This position will offer opportunities to focus on digital design in multi-disciplinary inertial and acoustic sensor interface SoCs. The candidate will primarily focus on:
•        Digital design and implementation for mixed signal/SoC ICs
•        Starting from Verilog RTL, and using industry standard tools, implementation of  design through synthesis, floor planning, clock tree synthesis and routing
•        Block level RTL design
•        Perform static timing analysis(STA) and help identifying and fixing timing problems
•        Perform design for test (DFT) and test pattern generation (ATPG)
•        Close interaction with analog/mixed signal designers.
Qualifications:
•        Master's degree with at least 5 years of experience with digital ASIC flow
•        Experience with  RTL design
•        Experience with RTL2GDS flow including synthesis, timing analysis, formal verification and DFT
•        Knowledge of  audio processing, signal processing, or SOC design is a big plus
•        Knowledge of scripting languages such as Perl and Tcl is a plus
•        Good English written and verbal communication skills
•        Excellent communication and team-oriented work skills
•        Self-motivated individual willing to take ownership and responsibility
2.Digital Verification Engineer (mixed signal/SoC)
Responsibilities:
This position will offer opportunities to focus on digital verification in multi-disciplinary inertial and acoustic sensor interface SoCs. The candidate will primarily focus on:
•        Setup verification testbench at module level and chip level,
•        Define and execute verification plan with full functional coverage
•        Doing gate level simulations
•        Doing mixed-signal co-simulations with the analog team
•        Interact with design team to achieve design quality and meet schedule target
•        Document and review detailed test plans and testbenches, and meet verification goals
•        Support silicon validation
Qualifications:
•        Master's degree with 5 years of experience with SoC/Mix-signals IC verification
•        Knowledge of OVM/VMM/UVM
•        Knowledge of Audio processing or signal processing or SOC design is a big plus
•        Familiar with digital & mixed signal verification tools, such as NC-verilog/Verdi/Vplan
•        Familiar with Verilog/ System Verilog/ System C language
3. Digital signal processing (OIS, Audio, Motion) Design Engineer
Responsibilities:
This position will offer opportunities to focus on digital signal processing design in multi-disciplinary inertial and acoustic sensor interface SoCs. The candidate will primarily focus on:
•        Algorithm design and implementation for optical image stabilization (OIS), motion, and audio applications
•        Defining and architecting the DSP design (filters, control loops, auto-calibration, and digitally enhanced analog signal paths) using Matlab or other industry standard tools
•        Algorithm validation and performance evaluation
•        Block level RTL implementation and verification in cooperation with the digital design team cooperation
•        Develop and research signal process algorithm for new generation sensors and related application areas
Qualifications:
•        Master/PHD's degree with 2+ years of experience with signal processing.
•        Very strong knowledge on digital signal processing
•        Experience with FIR/IIR filters (minimum requirement)
•        Knowledge of RTL implementation of algorithms in ASIC or FPGA
•        Knowledge of multi-rate and multi-resolution signal processing is a plus
•        Knowledge of audio or motion signal processing is a plus
•        Knowledge of sigma-delta modulators is a plus
•        Knowledge of LabView is a plus
4.Analog Mixed Signal Designer
This position will offer opportunities to focus on analog mixed signal in multi-disciplinary inertial and acoustic sensor interface SoCs. The candidate will primarily focus on:
•        Architecture, design, and validation of sensor interface ICs such as data converters (ADC/DAC), LDO, low noise amplifiers, bandgap, etc...
•        architecture, design, and validation of high precision and performance, low power analog circuits
•        providing technical guidance to layout, application, and validation engineers
•        create through specifications, review documents, and follow established design flow to maximize first silicon success
Qualifications:
•        Master/PHD's degree with at least 3 years of experience
•        Knowledge of acoustic and inertial sensor interfaces or is a plus
•        Solid understanding of analog design fundamentals is a must
•        Experienced in designing mixed-signal circuits in deep sub-micron processes
•        Firm understanding of oversampling sigma-delta data converters (ADC, DAC) fundamentals
•        Design, synthesis, and realization of NTF in both analog and digital modulator is a plus
•        Experienced in low power, high performance precision analog mixed-signal designs including op-amps, comparators, bandgap references, LDOs, PGAs, audio mixers, analog volume controls, and sensor front-ends
•        Experience in system level design, signal processing tools such as Matlab and Simulink is required
•        Familiar with design/simulation/verification tools including Cadence, Spice, Spectre, UltraSim
•        Knowledge of mixed-mode simulation using Verilog-A is a plus
•        Familiar with layout/extraction/back-end tool such as Cadence, Caliber, starRC, etc.
•        Familiar with silicon verification and debugging using test modes, micro-probing, and FIB experiments, etc.
在上海张江这边新开张, 急速扩张中, 美资外企,上市公司,待遇优厚,请速来
简历发: ypan@invensense.com
About  InvenSense
Website:  www.invensense.com
    InvenSense is the pioneer and global market leader in MEMS System on Chip (SOC) solutions. Our single-chip MotionTracking™ solutions combine micro-electromechanical system, or MEMS, based motion sensors, such as accelerometers and gyroscopes, with mixed-signal integrated circuits (ICs) to improve performance, accuracy, and intuitive motion- and gesture-based interfaces. InvenSense currently targets consumer electronics and industrial applications within a variety of end markets that we believe demand a more intuitive and immersive user experience, such as console and portable video gaming devices, smartphones, tablet devices, digital still and video cameras, digital television and set-top box remote controls, 3D mice, navigation devices, toys, health and fitness accessories, precision robotics, survey instruments, industrial power tools, precision agricultural machinery, guidance and steering applications, and construction equipment.
     At InvenSense, we take pride and find satisfaction in doing our jobs well, and we value the companionship that comes from working with others who share our total commitment to our customers and one another. We are looking to hire the brightest and talented professionals, to help us continue our impressive growth as a global market leader in MEMS SOC solutions. We offer career opportunities for talented and innovative people, who embrace challenges and have a passion for excellence.
     InvenSense is a high growth company and we are experiencing an ongoing and continual demand for many types of engineers such as Software Algorithm Engineers, MEMS Designers, Digital and verification engineers. If you excel in a fast paced, results-oriented work environment and have a progressive track record of innovation, excellent problem solving and communication skills, as well as the ability to work both as an individual contributor and as part of a cross-functional team, then InvenSense may be just what you’re looking for.
GMT+8, 2025-12-25 15:08 , Processed in 0.042086 second(s), 8 queries , Gzip On, Redis On.
