有没有人ALTERA自动生成PCIE,本人在生成完模型后,综合发现默认指定的pin脚信息综合出错,但是根据参考手册上说的该引脚应该可以使用的,百思不得其解,希望做个的大侠给个指导意见,不甚感谢!!!以下是综合出错信息。3 differential I/O pins do not have complementary pins. As a result, the Fitter automatically creates the complementary pins.
Info (184026): differential I/O pin "PCIE_TX" does not have a complementary pin. As a result, the Fitter automatically creates the complementary pin "PCIE_TX(n)".
Info (184026): differential I/O pin "PCIE_CLK" does not have a complementary pin. As a result, the Fitter automatically creates the complementary pin "PCIE_CLK(n)".
Info (184026): differential I/O pin "PCIE_RX" does not have a complementary pin. As a result, the Fitter automatically creates the complementary pin "PCIE_RX(n)".
Error (175020): Illegal constraint of Receiver channel to the region (0, 12) to (0, 14): no valid locations in region
Info (175028): The Receiver channel name: PCIE_RX
Info (175015): The I/O pad is constrained to the location PIN_AJ2 due to: User Location Constraints (PIN_AJ2)
Error (12289): An error occurred while applying the periphery constraints. |
