查看: 2281|回复: 9
[求助] 属性设置求助。。。。
发表于 2014-3-31 15:45:22 | 显示全部楼层 |阅读模式
这个器件 截图01.png ,我在参数性能设置中没有找到 截图02.png 交流信号的设置选项,请问该怎么解决,不设置仿真没法往下进行,谢谢各位。。。。
发表于 2014-3-31 21:11:13 | 显示全部楼层
你要仿真什么还必须设置小信号
 楼主| 发表于 2014-3-31 21:41:21 | 显示全部楼层
回复 2# fhy420462303
   在做低噪声放大器的Spectre仿真,学着教程做,可是那个设置中有这个要求,所以就出现了这个,但是在属性选项中没找到。。。求帮助。。。
发表于 2014-4-1 15:01:37 | 显示全部楼层
Hi lcw6021213:
The option is in the vsin, I think you used vsource.
So you need to change it.
mpig
 楼主| 发表于 2014-4-1 16:58:06 | 显示全部楼层
回复 4# mpig09
  thank you for your help,but it is just one of the options,you can see it: 截图03.png ,all of it must be set as this picture,I still can't find it ,it's a port model,I think it's not a vsource and vsin. I want to konw how to find,how to set it.Thank you for your guidance, and could you help me???
 楼主| 发表于 2014-4-1 17:07:01 | 显示全部楼层
回复 4# mpig09
  thank you for your help,but it is just one of the options,you can see it:,all of it must be set as this picture,I still can't find it ,it's a port model,I think it's not a vsource and vsin. I want to konw how to find,how to set it.Thank you for your guidance, and could you help me???
发表于 2014-4-2 09:37:50 | 显示全部楼层
Source type 要设置成"sine"才有你要的设置。默认是"DC"吧
 楼主| 发表于 2014-4-2 10:05:26 | 显示全部楼层
回复 7# ac3m666
   我已经设置成了sine,但还是没有这个,找不到。。。。
发表于 2014-4-2 10:38:25 | 显示全部楼层
Hi lcw6021213:
Thanks for you show the all parameters that you need to setting.
The symbol is "psin".
mpig
 楼主| 发表于 2014-4-2 20:31:50 | 显示全部楼层
回复 9# mpig09
Hi,mpig09:    Thank you for your kind help,I can solve this problem with your help.
                                         lcw6021213
GMT+8, 2025-10-16 23:49 , Processed in 0.018195 second(s), 4 queries , Gzip On, Redis On.
