查看: 6145|回复: 5
[求助] calibre command file 求解
发表于 2014-3-25 17:21:42 | 显示全部楼层 |阅读模式
各位大神,俺用calibre跑drc时,遇到问题如下:
FDC.add1 {@ IOPAD,POWERPAD need connect to the drain of the FDNMOS OR ESDN,GNDPAD need connect to the source of the FDNMOS OR ESDN;But the pad which connect the fdnmos should connect the esdpmos.
A = NET AREA RATIO PAD_11 DNW_D PBPF>0 [AREA(PAD_11)/(AREA(DNW_D)*AREA(PBPF))]
C = NET AREA RATIO PAD_11 DNW_S PBPF>0 [AREA(PAD_11)/(AREA(DNW_S)*AREA(PBPF))]
F = NET AREA RATIO PAD_11 DNW_D PBSF1>0 [AREA(PAD_11)/(AREA(DNW_D)*AREA(PBSF1))]
G = NET AREA RATIO PAD_11 DNW_D PBNF1>0 [AREA(PAD_11)/(AREA(DNW_D)*AREA(PBNF1))]
H = NET AREA RATIO PAD_11 DNW_S PBNF1>0 [AREA(PAD_11)/(AREA(DNW_S)*AREA(PBNF1))]
J = (A OR C) OR (F OR (G OR H))
(PAD_11 NOT INTERACT J) AND COVER
我按照上面描述重新连接,run后也会出现上面问题,请问上面语法中A、C、F、G、H、J是什么意思呢?
发表于 2014-3-25 20:24:20 | 显示全部楼层
这个命令本来就不是那么容易看懂,建议对应着drc rule手册看看~
从字面意义上看就是pad区域的一些问题,电源地pad要分别跟FDNMOS OR ESDN的漏源极相连,楼主做的是fullchip还是只是电路呢?
发表于 2014-3-25 23:05:30 | 显示全部楼层
FDC.add1 {@ IOPAD,POWERPAD need connect to the drain of the FDNMOS OR ESDN,GNDPAD need connect to the source of the FDNMOS OR ESDN;But the pad which connect the fdnmos should connect the esdpmos.  //这个地方是对这条rule的解释说明
A = NET AREA RATIO PAD_11 DNW_D PBPF>0 [AREA(PAD_11)/(AREA(DNW_D)*AREA(PBPF))]//A是与DNW_D PBPF有链接关系的PAD_11
C = NET AREA RATIO PAD_11 DNW_S PBPF>0 [AREA(PAD_11)/(AREA(DNW_S)*AREA(PBPF))] //C是与DNW_S PBPF有链接关系的PAD_11
F = NET AREA RATIO PAD_11 DNW_D PBSF1>0 [AREA(PAD_11)/(AREA(DNW_D)*AREA(PBSF1))]//F是与DNW_D PBSF1有连接关系的PAD_11
G = NET AREA RATIO PAD_11 DNW_D PBNF1>0 [AREA(PAD_11)/(AREA(DNW_D)*AREA(PBNF1))]//G是与DNW_D PBNF1有连接关系的PAD_11
H = NET AREA RATIO PAD_11 DNW_S PBNF1>0 [AREA(PAD_11)/(AREA(DNW_S)*AREA(PBNF1))]//H是与DNW_S PBNF1有连接关系的PAD_11
J = (A OR C) OR (F OR (G OR H)) //J是A C F G H的或运算产生的layer
(PAD_11 NOT INTERACT J) AND COVER //这个地方记不太清楚了,如果COVER不是关键字的话,这句的意思是抓出没有碰到J的PAD_11与COVER进行与运算产生的layer
//看注释的意思是PAD连到了FDNMOS同时连接到了ESDPMOS
//前面的运算看起来是抓的没有碰到J的PAD_11
不知道我理解对不对,好久没弄这个了
 楼主| 发表于 2014-3-26 09:58:26 | 显示全部楼层
回复 2# celestin2011
    fullchip,3Q
 楼主| 发表于 2014-3-26 22:10:01 | 显示全部楼层
回复 3# jdhubao
非常感谢,我去系统研究下这个语法,这还是有必要的!
发表于 2015-4-13 14:38:55 | 显示全部楼层
li han
GMT+8, 2025-12-30 01:03 , Processed in 0.018923 second(s), 6 queries , Gzip On, Redis On.
