查看: 4329|回复: 16
What Every Computer Scientist Should Know About Floating-Point Arithmetic
发表于 2014-3-24 08:02:24 | 显示全部楼层 |阅读模式
Floating-point arithmetic is considered an esotoric subject by many people. This is rather surprising, because floating-point is ubiquitous in computer systems:
Almost every language has a floating-point datatype; computers from PCs to supercomputers have floating-point accelerators; most compilers will be called upon to compile float-point algorithms from time to time;
and virtually every operating system must respond to floating-point exceptions such as overflow This paper presents a tutorial on the aspects of floating-point that have a direct impact on designers of computer systems. It begins with background on floating-point representation and rounding error, continues with a discussion of the IEEE floating-point standard, and concludes with examples of how computer system builders can better support floating point, Categories and Subject Descriptors:
(Primary)
C.0 [Computer Systems Organization]: General–instruction set design;
D.3.4 [Programming Languages]: Processors —compders, optirruzatzon;
G. 1.0 [Numerical Analysis]: General—computer arithmetic, error analysis, numerzcal algorithms
(Secondary)
D. 2.1 [Software Engineering]: Requirements/Specifications– languages;
D, 3.1 [Programming Languages]: Formal Definitions and Theory —semantZcs D ,4.1 [Operating Systems]: Process Management—synchronization General Terms: Algorithms, Design, Languages Additional Key Words and Phrases: denormalized number, exception, floating-point, floating-point standard, gradual underflow, guard digit, NaN, overflow, relative error, rounding error, rounding mode, ulp, underflow
Floating-Point Arithmetic.pdf (3.56 MB , 下载次数: 167 )
发表于 2014-3-26 01:30:45 | 显示全部楼层
old books !
发表于 2014-3-26 09:03:44 | 显示全部楼层
看看先
发表于 2014-3-26 20:43:50 | 显示全部楼层
谢谢楼主了,好好看看了。
发表于 2014-4-13 18:54:05 | 显示全部楼层
多谢楼主
发表于 2014-5-1 13:33:42 | 显示全部楼层
值得深刻学习!
发表于 2015-4-3 13:55:26 | 显示全部楼层
还不错,推荐
发表于 2016-3-21 19:17:26 | 显示全部楼层
谢谢提供
发表于 2016-3-21 20:19:18 | 显示全部楼层
回复 1# leasor
谢谢楼主分享!
发表于 2016-3-22 12:51:12 | 显示全部楼层
thnx!
GMT+8, 2025-9-17 03:22 , Processed in 0.024741 second(s), 5 queries , Gzip On, Redis On.
