楼主: zhule
ADS2014.01已经发布可以下载了,期待破解~~~~~~~~~~~~~~~~~
发表于 2014-10-3 12:42:53 | 显示全部楼层
感谢楼主分享
发表于 2014-10-3 16:42:20 | 显示全部楼层
回复 3# snk88
求助仿真出错:Simulation Messages
Error detected by hpeesofsim during circuit set up `SP1'.
    An appropriate license for linear features is not available.  This
    feature must be licensed before it can be used.
        FlexLM error message:
        Linear Simulator
        The desired vendor daemon is down
        Possible Causes:
        1. lmgrd process is running, but not the agileesofd vendor daemon. The software was able to contact the license server (lmgrd), but the vendor daemon (agileesofd) did not respond.
        2. agileesofd vendor daemon has crashed or has been terminated.
        3. lmgrd process was shut down manually or via LMTools with -x lmdown option
        4. On Windows platform, this could be caused by waking up from Sleep or Hibernation mode.
        5. The logfile was unable to be removed.
        Troubleshooting Tips:
        1. Check the license server's debug log file and try lmreread.
        2. Reboot your system to restart the license service.
        3. Use LMTools to clear your previous setup first, then restart license setup wizard to re-configure your license.
        4. Shut down the lmgrd process and check that lmgrd or agileesofd processes are no longer running. Restart the license server.
        5. Stop lmgrd via kill pid (UNIX) withough -9 argument or stop the lmgrd process through the Windows Task Manager or Windows Service.
        6. Close all processes that are reading the logfile.
        License Requested:  pb_ak1
        License path:  D:\Agilent\EEsof_License_Tools\bin\license.lic
Status / Summary
hpeesofsim (*) 410.shp Mar 17 2014 (64-bit built: 03/17/14 17:33:40)
Copyright Agilent Technologies, 1989-2014.
发表于 2014-10-3 16:48:14 | 显示全部楼层
大家帮忙看看:Error detected by hpeesofsim during circuit set up `SP1'.
        Linear Simulator
        Possible Causes:
Status / Summary
发表于 2014-10-5 21:00:38 | 显示全部楼层
要是有32位的就好了
发表于 2014-10-5 23:57:52 | 显示全部楼层
太感谢了,速度很快呀。試看看
发表于 2014-10-6 00:28:29 | 显示全部楼层
不能用
发表于 2014-10-7 09:45:38 | 显示全部楼层
考 我怎么打不开
发表于 2014-10-9 02:44:37 | 显示全部楼层
perfedcttttt
发表于 2014-10-10 13:50:31 | 显示全部楼层
回复 91# foxman_1
     看了 这个破解的讨论终于解决了ADS2013.06的安装,能运行满足要求就ok了感谢楼主感谢大家!!!!
发表于 2014-10-11 06:50:16 | 显示全部楼层
感谢分享
GMT+8, 2025-12-28 12:30 , Processed in 0.018499 second(s), 5 queries , Gzip On, Redis On.
