查看: 2173|回复: 0
[招聘] Cadence SH 招聘高级数字后端产品测试工程师
发表于 2014-3-21 18:04:36 | 显示全部楼层 |阅读模式
Joblocation: Shanghai
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your update CV to zhangyl@cadence.com
1. Principal/Lead Product Validation Engineer
Position Description:
Cadence ICD Product Validation Analysis Teammainly focuses on STA and Low Power related area in digital design backendflow.
1. This position is responsible for developing,applying and improving quality standard for Cadence Lower Power flow and Encountercommon timing engine.
2. The candidate needs to test Low PowerSolution and timing analysis result in common and special usage flows.
Detailed Responsibility:
1. Identify Low Power solution and timingsign-off challenges in complex SOC designs and advanced process nodes
2. Proactively provide Low Power & STA &Sign-off development suggestions to R&D.
3. Build up Lower Power & STA & Sign-Offexpertise and deliver support to field team and customers whenever needed.
4. Required to acquire expertise and ownershipover existing product components as well as develop brand new product features.
5. Project leader on important Low Power or STAfeatures.
Position Requirements:
1. Bachelor with 6 years related experience orMaster with 4 years related experience in design house, FAB or EDA Company.
2. Rich experience in IC design flow (front-endor back-end).
3. Experience in STA and SI analysis, orexperience in Low Power flow, knowledge in parasitic extraction and signoff isa strong plus.
4. Good Unix System knowledge and script skillof TCL/TK/CSH/PERL.
5. Excellent capability of self-learning,problem solving skills;
6. Being proactive and self-motivated;
7. Strong leadership;
8. Good written English and oral English is astrong plus
2. Senior Product Validation Engineer
•Thisjob is an important addition to Encounter quality and performance
•Responsiblefor Encounter/RC related Rubicon-lit/Rubicon database validation in EDI release
•Responsibleto co-work with RnD team closely to maintain stable database quality fromtesting view
•Workingclosely with other team members for technique communication and projects.
•BS withminimum 2~3 years or MS in EE background, from design house or EDA company isstrong plus.
•Befamiliar with software development process, debugging tools, and configurationmanagement concepts.
•Goodknowledge at backend flow in digital design will be a plus
•Somedeep understanding for database/GUI/TCL will be a plus
•Excellentability to learn, explore and strong ability in solving problems independently
•Goodteam working attitude and innovating spirit.
•GoodChinese and English communication skills.
3. SeniorProduct Validation Engineer
PositionDescription
This job is animportant addition of our R&D team to develop Cadence Encounter DigitalImplementation System (EDI) and the major focus is Router.
Responsible for developing, applying, andimproving quality standard for Cadence EDI products
Required to acquire expertise andownership over existing product components as well as develop brand new productfeatures.
Help identifying new technologychallenges in advanced process nodes and proactively provide the productimprovement suggestions to R&D.
PositionRequirements
CS/EE BS degreewith 3+ years or MS degree with 1+ years of EDA or IC design relatedexperience.
Basic knowledge andexperience of backend design flow using EDA tools.
Chip layoutintegration and successful tape-out experience, can use DRC/LVS sign off toolfor physical verification is strong plus.
Stronganalysis/debug capability for technical issues, be detailed oriented with afocus on quality.
Good team playerwith strong written and verbal communication skills.
Be able to workunder pressure, be able to work on multiple projects at the same time.
Good English read,write and communication Skill.
4. SeniorProduct Validation Engineer (for GPS)
PositionDescription:
This engineer will work in Encounter GPS(Global Physical Synthesis) product validation team. The responsibilitiesinclude:
a) Assist in Cadence EDI development andvalidation
b) Validate and maintain comprehensive GPS unitand flow test cases for Encounter Digital Implementation System.
c) Develop test suites of the new features ofEDI GPS function
PositionRequirements:
a)MS of EE/CS
b)Digital IC design knowledge is necessary,statistic timing analysis knowledge is a strong plus
c)Unix System knowledge, vi/TCL/TK/CSH/Perlwill be plus.
d)Good communication in English and Chinese,good confidence and self-motivation.
GMT+8, 2025-12-25 17:52 , Processed in 0.017147 second(s), 7 queries , Gzip On, Redis On.
