查看: 2442|回复: 1
[讨论] 这个加法器什么意思?
发表于 2014-3-19 08:43:13 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity adder1 is
  port(a,b:in signed(7 downto 0);
      clk,en:in std_logic;
result: buffer signed(7 downto 0));
end adder1;
architecture dataflow of adder1 is
begin
   process(clk,en,a,b)
    begin
       if(clk'event and clk='1'and en='1')then
       result<=a+b;
  if(a(a'left)=b(b'left))and result(result'left)/=a(a'left) then
    result<=(result'left=>a(a'left),
             others=>not a(a'left));
   end if;
    end if;
end process;
end dataflow;
 楼主| 发表于 2014-3-19 08:45:26 | 显示全部楼层
如果a,b的左端都为1那么结果为100 0000  ?
GMT+8, 2025-12-22 08:03 , Processed in 0.021077 second(s), 6 queries , Gzip On, Redis On.
