查看: 1516|回复: 0
[招聘] Cadence招聘Principle/Lead Verification Engineer (数字前端验证)
发表于 2014-3-10 11:44:20 | 显示全部楼层 |阅读模式
Location SH
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you haveinterest, PLS send your update CV to zhangyl@cadence.com
Position Description:
Deliver/implementadvanced verification solutions by utilizing Cadence’s Incisive Verificationproduct portfolio. The engineer should be able to act as a strong team memberand contributor, leading team projects and initiatives. Exercise judgmentwithin generally defined practices and policies.
Specificduties include:
-- Deepunderstanding on ASIC/SOC design flow
-- Excellentknowledge of advanced verification methodology like eRM/OVM/UVM
-- Familiarwith Cadence’s Incisive Plan to Closure Methodology (IPCM)
--Proficiencyin System Verilog,  System C and/or e(Specman)
-- Developingand using Verification Components (eVC, OVC, UVC, VIP)
-- Developingand using assertion based verification and formal analysis methods
--Skilledin scripting language, such as Perl, C shell, Makefile
-- Assessingthe project verification requirements
-- Operatingin a lead role regarding architecting and implementation of project
     verification environment/solution.
-- Maycoordinate/lead others within the scope of a defined project
  Position Requirements:
-- Musthave BS degree with 10+ years of applicable experience, MS degree with 7+ yearsof applicable experience in electrical engineering, microelectronics,comparable engineering science or solid state physics. Essential that the individualdemonstrates strong communication, verbal and written. Requires goodcommunication skills in English.
Desirable Qualifications:
-- Aminimum of seven years relevant experience in industry.
-- Willhave demonstrated hands-on experience and expertise with Cadence verificationdesign tools or equivalent tools, flows and methodologies required to execute averification project.
-- Willhave demonstrated successful completion of 10+ verification projects as anindividual contributor
-Preferto have DDR IP verification experience
GMT+8, 2025-12-25 11:28 , Processed in 0.014346 second(s), 4 queries , Gzip On, Redis On.
