查看: 2922|回复: 0
difference between IO PAD and Core Pad
发表于 2014-3-4 10:31:40 | 显示全部楼层 |阅读模式
刚才想知道IO PAD和Core PAD的区别,百度没出来,谷歌出来的东西,讲的很清楚。
Difference in layout between a core and i/o power pad
Hi
Can Anyone tell me the difference between a core and i/o power pad in a digital design with respect to their layouts??
I have a umc library which claims to have separate core (VCCK)and i/o (VCCIO) power pads. But the respective layouts look similar. I know that the core and i//o pads serve different purposes.
Thank you
the core pad is only here to provide power to the core, so must be connected to the std-power ring instead the i/o power pad, that provide the power for the pad power ring.
Re: Difference in layout between a core and i/o power pad
Thank u ... but as said earlier I know there lies a difference in the purpose of using core and I/O pads. All I want to know is the differnce in the internal structure(layout) of the respective pads. Can anyone throw some light on this?
I dont knw abt the UMC , but for TSMC . wen you load both kind IO's into encounter. you can definitely see difference in the lef definition, Normally for a Core Io , pins are defined and wen you enable instance pin option in encounter you can see the metal pins on these core pads but not on IO pads.
Br
Sing
Is that the only difference? Isn't there any difference in the internal structure of these pads, because they serve different purpose?
GMT+8, 2025-12-25 20:52 , Processed in 1.102309 second(s), 5 queries , Gzip On, Redis On.
