查看: 5873|回复: 3
[原创] 从cadence导出网表用Hspice仿真出错
发表于 2014-2-28 15:55:37 | 显示全部楼层 |阅读模式
导出的网表:
  1. *  Generated for: HSPICE
  2. *  Generated on: Feb 28 10:53:03 2014
  3. *  Design library name: CMOS_simulation
  4. *  Design cell name: Constant_current
  5. *  Design view name: schematic
  6. .global 0
  7. .option search='e:\hspice_mutisim\st02_model'  ***这两行是我
  8. .lib 'st02.lib' tt                                                 ***添加的库文件
  9. .temp 25
  10. .option ARTIST=2 PSF=2
  11. *  Library name: st02
  12. *  Cell name: rhr2k
  13. *  View name: schematic
  14. .subckt rhr2k_pcell2461 minus plus
  15. +  segR=14.4154K segL=10u segW=1.3u
  16.     xr0 plus minus rhr2k segR M=1 L=segL W=segW
  17. .ends
  18. *  End of subcircuit definition.
  19. *  Library name: CMOS_simulation
  20. *  Cell name: Constant_current
  21. *  View name: schematic
  22. v1 net11 0 dc=0
  23. v0 net025 0 dc=2.5
  24. xr1 net27 net025 rhr2k_pcell2461 m=1 segR=380.566e3 segL=264e-6 segW=1.3e-6
  25. mpm1 net19 net19 net025 net025 mp L=5e-6 W=70e-6 AD=84e-12 AS=84e-12 PD=142.4e-6 PS=142.4e-6 M=1
  26. mpm0 net15 net19 net025 net025 mp L=5e-6 W=70e-6 AD=84e-12 AS=84e-12 PD=142.4e-6 PS=142.4e-6 M=1
  27. mnm4 net11 net15 net17 0 mn L=5e-6 W=15e-6 AD=15.75e-12 AS=15.75e-12 PD=32.1e-6 PS=32.1e-6 M=1
  28. mnm8 net15 net17 0 0 mn L=5e-6 W=15e-6 AD=15.75e-12 AS=15.75e-12 PD=32.1e-6 PS=32.1e-6 M=1
  29. mnm6 net19 net27 0 0 mn L=5e-6 W=15e-6 AD=15.75e-12 AS=15.75e-12 PD=32.1e-6 PS=32.1e-6 M=1
  30. mnm9 net17 net27 0 0 mn L=5e-6 W=15e-6 AD=15.75e-12 AS=15.75e-12 PD=32.1e-6 PS=32.1e-6 M=1
  31. mnm7 net27 net27 0 0 mn L=5e-6 W=15e-6 AD=15.75e-12 AS=15.75e-12 PD=32.1e-6 PS=32.1e-6 M=1
  32. .dc v1 0 5 1
  33. .end
    复制代码
simulate后就出现
**error** reference        0:segr             not found or not correct type for the element model
      it was referenced in element         1:xr0
    the line number was      15
的错误。
各位大神,帮小弟解决一下啊!万分感谢!
发表于 2014-2-28 18:45:12 | 显示全部楼层
xr0没有定义, HSPICE 网标和Cadence的是不一样的。xr0 plus minus rhr2k segR M=1 L=segL W=segW,这句后面要有调用的subckt名字。
 楼主| 发表于 2014-3-1 17:11:07 | 显示全部楼层
回复 2# lwjee
嗯,我知道。但我不知该如何改。我直接用cadence里的spectre也仿不出来,依然说是电阻的问题。在画原理图的时候该如何选择电阻啊?
发表于 2016-1-20 18:11:10 | 显示全部楼层
rhr2k_pcell2461
GMT+8, 2025-12-21 13:31 , Processed in 0.016373 second(s), 6 queries , Gzip On, Redis On.
