查看: 5803|回复: 13
[求助] A 1.39-V input fast-transient-response digital LDO
发表于 2014-2-28 15:25:57 | 显示全部楼层 |阅读模式
帮忙下篇文章A 1.39-V input fast-transient-response digital LDO composed of low-voltage MOS transistors in 40-nm CMOS process
Published in:
Solid State Circuits Conference (A-SSCC), 2011 IEEE Asian Date of Conference:
14-16 Nov. 2011 Page(s):37 - 40 Print ISBN:978-1-4577-1784-0 INSPEC Accession Number:12459733
发表于 2014-2-28 18:58:51 | 显示全部楼层
回复 1# wangsun
∗ Currently with The Univ
E-mail: masafumi.
Abstract—A fast transient-response digital low-dropout (LDO
voltage regulator comprising only low-voltage MOS transistor
was developed. The input voltage can be higher than th
withstand voltage of the low-voltage MOS transistors by th
proposed withstand-voltage relaxation scheme. The switchin
frequency of 1 GHz can be achieved using small-dimension low
voltage power-MOS transistors. The LDO occupies only 0.05
mm2
area using 40-nm CMOS technology, and covers a wid
06123569.pdf
544.26 KB, 下载次数: 239 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-2-28 19:58:10 | 显示全部楼层
abstract?
 楼主| 发表于 2014-3-3 09:16:28 | 显示全部楼层
一篇论文。
To : liazhen
非常感谢,下载了!
发表于 2015-10-13 14:18:25 | 显示全部楼层
非常感谢,
发表于 2015-10-13 15:58:09 | 显示全部楼层
kankan
发表于 2015-10-13 17:36:31 | 显示全部楼层
网络资源丰富
发表于 2015-10-13 18:46:21 | 显示全部楼层
受益匪浅,好
发表于 2016-6-9 16:08:58 | 显示全部楼层
THANK YOU
发表于 2016-6-9 16:11:36 | 显示全部楼层
THANK YOU
GMT+8, 2025-12-25 15:43 , Processed in 0.033326 second(s), 6 queries , Gzip On, Redis On.
