查看: 3463|回复: 4
simulation library compilation wizard 生成仿真库有误
发表于 2014-2-26 09:29:54 | 显示全部楼层 |阅读模式
我用的是ISE14.4,在用simulation library compilation wizard 生成仿真库文件时有误,报错为:(1)64位系统上报QuestaSim vlog 6.5e Compiler 2010.02 Feb 26 2010** Error: (vlog-1902) Option "-64" is either unknown, requires an argument, or was given with a bad argument.
Use the -help option for complete vlog usage.
(2)32位系统上报QuestaSim vlog 6.5e Compiler 2010.02 Feb 26 2010** Error: (vlog-1902) Option "-32" is either unknown, requires an argument, or was given with a bad argument.
请各位大侠帮忙解决解决!!!
发表于 2014-2-26 09:43:15 | 显示全部楼层
more detail
 楼主| 发表于 2014-2-26 09:46:05 | 显示全部楼层
我用的仿真软件是Questasim 6.5e ,我用ise12.3是能生成的,但用14.4就报以上错误
发表于 2014-2-26 11:13:13 | 显示全部楼层
学习几个英语单词那么难吗
 楼主| 发表于 2014-2-26 16:02:40 | 显示全部楼层
我知道不知如何做啊?我属于菜鸟级的
GMT+8, 2025-12-20 19:23 , Processed in 0.022339 second(s), 6 queries , Gzip On, Redis On.
