楼主: meidierli
[求助] 基准的psrr曲线,怎么提高“带宽”
发表于 2014-2-18 15:15:21 | 显示全部楼层
回复 10# caxias
请问 第二种方法 加入 subtractor 具体怎么实现?
发表于 2014-2-18 20:22:35 | 显示全部楼层
Subtractor meaning:Between stage1 and pmos output pass transistor, insert a common source stage with diode connected load. Ensure that gain of this stage is slightly less than 1 (gm1/gm2)<1 ). The diode connected pmos will replicate the supply noise on the pass transistors gate and hence PSRR will be better. Use an external capacitor to compensate the LDO.Try and let me know if you see any issues.
发表于 2014-2-18 20:35:55 | 显示全部楼层
增加功耗
发表于 2014-2-18 21:10:10 | 显示全部楼层
Agree with extra power dissipation , but this seems to be the best way since it only increases in proportion to the load. With the standard LDO architecture you will need to burn not less than 300uA in the second stage (pmos pass stage) to achieve 30dB at 1Mhz and still be stable.If you use other architectures such as using an amplifier to cancel out the noise on the gate,it would work only for a specific range of load currents and even this method consumes not less than 70u-80u extra current.
 楼主| 发表于 2014-2-19 20:22:10 | 显示全部楼层
回复 12# caxias
  顶一顶 试一试
这是现在的psr
 楼主| 发表于 2014-2-19 20:35:46 | 显示全部楼层
回复 7# tmdyumf
   12楼的方法是不是增加运放的带宽? lpf是什么。。。 电容吗?
发表于 2014-2-19 21:10:01 | 显示全部楼层
回复 15# meidierli
   密切关注这个问题
楼上的图是到多少hz了啊,看不到啊
发表于 2014-2-19 21:10:30 | 显示全部楼层
回复 15# meidierli
    图不清楚 尺度看不出来
发表于 2014-2-19 21:13:48 | 显示全部楼层
回复 12# caxias
这个有论文嘛?上传一个吧,感谢ing
 楼主| 发表于 2014-2-19 21:23:37 | 显示全部楼层
回复 17# po123
   横线那里是80, 横坐标一大格  0, 10, 100,1000,10k。。。。。。。。。。
GMT+8, 2025-12-13 18:10 , Processed in 0.221397 second(s), 4 queries , Gzip On, Redis On.
