查看: 1473|回复: 0
[招聘] NO.316-Integration Engineer(Suzhou)
发表于 2014-2-13 17:12:45 | 显示全部楼层 |阅读模式
Job Description:
·         MEMS Technical/Integration expert for consulting customer projects
·         Hands-on work doing
o    MEMS process engineering, process integration, simulation and basic design
o    DOE design, Data Analysis and Report Generation
o    MEMS bench testing and device testing
o    Project Planning/ Scheduling
Job Summary:
·         The engineer will serve as a MEMS Integration/Test engineer to support customers in demonstrating concept and feasibility of new MEMS devices and technology using company’s IC and customer IP.
·         The engineer will use, and help customers to use, the Company’s IC Technology Development Process (TDP).
·         The engineer must have a strong background in MEMS process, integration, bench test, inline e-test, test program creation and have a strong understanding of test requirements/parameters.
·         The engineer will help with basic MEMS design and simulation tasks.
·         The engineer must be aware and sensitive of IP protocols to accomplish tasks including protection of foreground IP of the customer and development of foreground IP for company’s IC following contractual obligations.
·         The engineer is expected to work collaboratively with the customer in order to establish detailed project plans and deliverables, and to conduct engineering work with the customer.
Key Tasks/Duties/Responsibilities of this Position:
·         Serve as a technical expert to the customer by helping them plan and carry out engineering work required to make the customer product successful and manufacturable.
·         Create reports and present the results to the customer, writing summary reports and presentations, and attending selected technical conferences.
Requirements
·         B.S. (M.S. or PhD preferred) in Materials Science, Electrical Engineering or Physical Sciences
·         Strong ability to read, write, and speak English and Mandarin
·         Experience as a consulting engineer would be very desirable.
·         Experience doing MEMS device modeling using ANSYS, Coventor, or other similar tools would be very desirable.
·         Experience with basic MEMS device design CAD tools would be very desirable.
·         Requires > 7years’ experience in advanced MEMS/semiconductor process and integration technology development and testing.
·         Requires deep knowledge of advanced MEMS semiconductor processing, integration and device design, and process flow creation and electrical result/Failure analysis evaluation.
·         Background in device physics and experience with process and device simulation are helpful.
·         Requires:
o    Strong ownership/responsiveness in a customer environment as a consultant
o    Strong technical team direction skills
o    Good data analysis/statistics skills
o    Good oral/written communication skills in English and Mandarin
·         Requires ability to communicate and interface with all levels of management in customer organizations.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-25 15:48 , Processed in 0.011447 second(s), 3 queries , Gzip On, Redis On.
