查看: 1437|回复: 0
[招聘] Test Engineering
发表于 2014-2-13 16:54:00 | 显示全部楼层 |阅读模式
Develop test strategies, testmethods and test specifications for new products, resulting in an  ATE (Automated Test Equipment) test plan.
2)
Work closely with designerand Program Manager to define DFT/DFx solution to match the lowest test costand “zero defect” quality.
3)
Responsible for theimplementation/debugging and release of the industrial test facility (bothhardware and software) in test manufacturing sites, meeting the industrialrequirements on reproducibility, stability and test costs.
4)
Responsible for Hardwarecreation( loadboard / probe card/ kits. etc) and release to match projectschedule.
5)
Create Test program/hardware release report and correlation report based on test data/result
6)
Develop characterizationtest program in order to characterize the performance of assigned products, inclose cooperation with Product Engineer and Designers.
7)
Work and communicate closelywith team members (inside/outside the product line)  to ensure project schedules are met
8)
Work closely together withengineers at manufacturing sites to ensure smooth flow of operations intesting.
Profiles:
1)
MSEE or BSEE with3~5 years
testingexperience
2)
Solid C/C++ codingskill(VB/Perl is preferred)
3)
Knowledge with orCAD(protel)or similar to create schematics for loadboards
4)
Familiar with massproduction release flow from design house to testing site
5)
Skilled testing capabilityfor various IC product( Analog/Digital/ Mix-signal)
6)
Diligent/ quick learning/ interestingin digging into problems and sharing knowledge
7)
Goodcommunication both in oral and written English
8)
Good team player with focus on results andtime management
GMT+8, 2025-12-25 08:25 , Processed in 0.012803 second(s), 4 queries , Gzip On, Redis On.
