SI/PI Engineer (信号完整性工程师) Location: Shanghai
Position Description: Complete power-delivery system analysesacross chips, packages and boards. System-level SI analysis, includingsimultaneous switching noise analysis of high-speed signal transmissions, andadvances physical design for single- and multi-chip packages, states-of-the-art3D packages, and systems in packaged (SiP). The engineer should be able to actas a strong team member and contributor. Specific duties include: - Be responsible for building SI/PI/SiPdesign flow for High-speed IP Design - Proficiency in cadence tools: Allegro andSigrity - Proficiency in Hspice or spectresimulation, especially in high-speed simulation. - Good knowledge in modeling, for exampleIBIS. - Good knowledge in high-speed PCB design. - At least eight years experience focus onSiP and SI/PI analysis, excellent communication skills and the uncanny abilityto both lead and contribute in a cooperative team environment is required.
Position requirements: Essential Qualifications: 1. Must have BS degree with 10+ years ofapplicable experience, MS degree with 7+ years of applicable experience inelectrical engineering, microelectronics, comparable engineering science orsolid state physics. 2. Essential that the individualdemonstrates strong communication, verbal and written. Requires goodcommunication skills in English.
Desirable Qualifications: A minimum of seven years relevantexperience in industry. - At least five years experience drivingSiP/PI/SI project. - Will have demonstrated successfulcompletion of 10+ projects as an individual contributor
