查看: 6274|回复: 9
Agilent N1930B Physical Layer Test System (PLTS) 2013 UP1
发表于 2014-2-9 01:35:02 | 显示全部楼层 |阅读模式
With 2014 being released soon I thought I would share this...
http://thepiratebay.se/torrent/9589620/Agilent_N1930B_Physical_Layer_Test_System_%28PLTS%29_2013_UP1
All you have to do is extract with 7-zip or equivalent un-archiving tool. Run the setup (msi file). Select the license on first run (it is included in the archive as well as placed in the installation directory of PLTS under the license folder. Enjoy and please seed for as long as you can. Thanks.Enhanced Eye Diagram Capabilities: Complementing the existing pre-emphasis and equalization features of PLTS 2012, six new features have been added including color graded eye diagram to show density, configuration eye diagram measurements through sampling window, eye diagram equations and more.Calibration and Measurement: Leveraging the breakthrough Automatic Fixture Removal (AFR), a new non 50-ohm fixture algorithm has been added for newer technology standards. TRL wizard enhancements, more accurate skew measurements, and ENA calibration enhancements are now available.Ease-of-Use: Many GUI enhancements make PLTS the simplest and most intuitive PLTS yet. These enhancements include new marker and marker math table, user span for marker search and trace statistics, smart spin buttons on scaling bar, set trace as limit line, and gating view enhancements.Miscellaneous enhancements: -Reads PNA balanced *.snp Touchstone data -Correlated impedance with DCA-J sampling scope -Plot panning for quick visual assessment of data
发表于 2014-2-11 17:48:38 | 显示全部楼层
这是什么格式的文件?
后缀名是什么?
是Agilent N1930B Physical Layer Test System (PLTS) 2013 UP1.7z ?
发表于 2014-2-15 01:28:10 | 显示全部楼层
Can share the lic ? thanks !
 楼主| 发表于 2014-3-17 12:25:06 | 显示全部楼层
这是什么格式的文件?
后缀名是什么?
是Agilent N1930B Physical Layer Test System (PLTS) 2013 UP1.7z ...
zxdr5 发表于 2014-2-11 17:48
    .7z archive (compressed)
 楼主| 发表于 2014-3-17 12:26:15 | 显示全部楼层
Geant168 发表于 2014-2-15 01:28
    license is located in agilent plts installation directory after installation. folder is named license.
发表于 2014-3-17 13:31:24 | 显示全部楼层
haodongxi!
发表于 2014-5-13 16:22:11 | 显示全部楼层
感謝大大的分享,再感謝..........
发表于 2014-5-17 16:19:43 | 显示全部楼层
失效了
发表于 2015-6-29 11:16:12 | 显示全部楼层
可以再提供載點嗎?
发表于 2019-8-6 13:31:10 | 显示全部楼层
不知道会不在提供一下
GMT+8, 2025-12-14 13:17 , Processed in 0.021527 second(s), 8 queries , Gzip On, Redis On.
