查看: 11279|回复: 21
求助:TECplot画图区域呈雪花状,看不见图形
发表于 2014-2-3 07:17:11 | 显示全部楼层 |阅读模式
如题,有哪位大牛能给点意见吗?
 楼主| 发表于 2014-2-3 07:18:26 | 显示全部楼层
为什么没有图片?再传一次。
Screenshot from 2014-02-02 17:07:25.png
 楼主| 发表于 2014-2-3 08:54:20 | 显示全部楼层
貌似找到问题所在:libGL error: failed to load driver: r600 和 libGL error: failed to load driver: swrast,意思是没有找到这两个驱动,造成无法渲染。本机上这些驱动是有的,在/usr/lib/dri下,初步判断是因为不同版本的linux下驱动安装位置不一样造成的。
请哪位TECplot能够正常运行的好心人帮我看看你机器上的r600_dri.so和swrast_dri.so的具体路径,麻烦在这里留下你机器上这两个文件的路径。不胜感激之至!!!
 楼主| 发表于 2014-2-4 01:36:22 | 显示全部楼层
问题解决,不是路径的问题,是gcc的版本问题。重装gcc后果然好使了。
Screenshot from 2014-02-03 10:19:47.png
发表于 2014-3-29 00:34:58 | 显示全部楼层
回复 4# yankang84
Hello, I've got the same problem in Fedora 20, could you give some details about how to reinstall gcc, which version?
Thanks.
发表于 2014-3-29 09:15:45 | 显示全部楼层
回复 4# yankang84 你好,能否告知重装gcc什么版本,原来的版本要卸载吗?FC20,谢谢
 楼主| 发表于 2014-4-1 01:31:22 | 显示全部楼层
回复 6# sjsware
I'm so sorry for that i didn't give you a respond earlier for the reason that i was busy with other things.  you should use the command "string /usr/lib/libstdc++.so.6|grep GIBC++" to see what kinds of GLIBC++ versions this lib contains. And then use the same command to see the contents of the lib of libstdc++.so.6 in your directory in which sentaurus installed (in my computer,it is "/home/myname/sentaurus2012/tcad/G-2012-sp2/linux/lib/libstdc++.so.6") .you will find some difference, and then you can install the  version which the lib in sentaurus directory contains. hopping all of these could help you!!
 楼主| 发表于 2014-4-1 01:36:40 | 显示全部楼层
回复 6# sjsware
发表于 2014-4-1 12:24:49 | 显示全部楼层
回复 8# yankang84
Oh my gosh,I wiLL TRY LATER.
Thanks.
发表于 2014-4-2 15:07:31 | 显示全部楼层
回复 8# yankang84
I found some differences between these two commands:
[root@jinshan ~]# strings /usr/lib64/libstdc++.so.6 |grep GLIBC
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
GLIBC_2.3
GLIBC_2.2.5
GLIBC_2.14
GLIBC_2.4
GLIBC_2.3.2
GLIBCXX_DEBUG_MESSAGE_LENGTH
[root@jinshan ~]# strings /home/alain/synopsys/sentaurus/tcad/H-2013.03-SP2/amd64/lib/libstdc++.so.6 |grep GLIBC
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBC_2.2.5
GLIBC_2.3
GLIBC_2.3.2
GLIBCXX_FORCE_NEW
What should I do next? Installer the absent version?
GMT+8, 2025-12-20 22:30 , Processed in 0.028620 second(s), 7 queries , Gzip On, Redis On.
