查看: 1937|回复: 1
[求助] 求IEEE文章 关于automatic tuning
发表于 2014-1-23 18:14:57 | 显示全部楼层 |阅读模式
A 43dB ACR low-pass filter with automatic tuning for low-IF conversion DAB/T-DMB tuner IC
This paper provides a channel select low-pass filter with automatic cut-off frequency tuning circuit for low-IF conversion digital audio broadcasting (DAB) and terrestrial-digital multimedia broadcasting (T-DMB) tuner IC. This filter has 1.58MHz cut-off frequency, 20dB and 65dB stop band attenuation at 1.9MHz and 2.4MHz, respectively. The in-band IIP3 is -8.4dBV and 1dB desensitization is satisfied for 490mVpp interferer at 1.7MHz frequency offset. By using simple automatic tuning technique, less than +/-1.5% cut-off frequency error and more than 40dB adjacent channel rejection (ACR) are obtained. The low-pass filter is fabricated in 0.18μm CMOS technology and consumes about 4.5mA with 1.8V power supply.
Published in:
Solid-State Circuits Conference, 2005. ESSCIRC 2005. Proceedings of the 31st European
非常感谢
发表于 2014-1-23 22:43:15 | 显示全部楼层
0319kim.pdf (314.49 KB , 下载次数: 11 )
GMT+8, 2025-12-26 08:28 , Processed in 0.024201 second(s), 7 queries , Gzip On, Redis On.
