RED hat 5 EL下安装ADS2011.01,出现 Agilent Technologies
Advanced Design System
Advanced Design System requires the installation of the RPM openmotif22...
The following files are missing from your system, you need to run yum install openmotif22
or install the openmotif22-2.2.3-18 RPM(s) from the RedHat 5 distribution media.
/usr/lib/libXm.so.3 /usr/lib64/libXm.so.3
On 64-bit systems, you need to install the i386 and x86_64 versions of the RPM openmotif22-2.2.3-18
Running yum install openmotif22 on a x86_64 system will install both versions on your system
,安装RPM openmotif22-2.2.3-18时候出现
warning: /home/cad/Desktop/openmotif22-2.2.3-18.x86_64.rpm: Header V3 DSA signature: NOKEY, key ID 37017186
error: can't create transaction lock on /var/lib/rpm/__db.000
哪一位能帮忙解决一下,不胜感激
