查看: 2756|回复: 7
[资料] Agilent loadpull and example
发表于 2014-1-18 20:38:51 | 显示全部楼层 |阅读模式
loadpull sequence for pa.pdf (1.74 MB , 下载次数: 120 )
20110822_LoadPull.zip (2.78 MB , 下载次数: 100 )
发表于 2014-1-18 21:44:50 | 显示全部楼层
see see
发表于 2014-1-18 22:13:09 | 显示全部楼层
非常感谢提供!
发表于 2014-1-19 03:14:47 | 显示全部楼层
good job!
发表于 2014-1-19 03:16:06 | 显示全部楼层
Load pull measurements are used to study the response of a device-under-test (DUT) under multiple source and load impedances.
发表于 2014-1-19 03:16:33 | 显示全部楼层
Traditional load pull measurements utilize a passive mechanical tuner to vary the impedance seen by the DUT.
发表于 2014-1-19 03:17:01 | 显示全部楼层
Active load pull measurements use an external signal source to inject a signal into the output of the DUT in order to emulate the effect of a reflected signals.
发表于 2014-1-19 08:16:38 | 显示全部楼层
不知道什么样的资料啊,多谢楼主
GMT+8, 2025-12-26 19:26 , Processed in 0.822797 second(s), 7 queries , Gzip On, Redis On.
