查看: 26869|回复: 96
[资料] 2014 springer 新书:Architectures for Baseband Signal Processing
发表于 2014-1-17 11:45:28 | 显示全部楼层 |阅读模式
Book Description[size=0.86em]Publication Date: August 26, 2013 | ISBN-10: 1461480299 | ISBN-13: 978-1461480297 | Edition: 2014
This book addresses challenges faced by both the algorithm designer and the chip designer, who need to deal with the ongoing increase of algorithmic complexity and required data throughput for today’s mobile applications. The focus is on implementation aspects and implementation constraints of individual components that are needed in transceivers for current standards, such as UMTS, LTE, WiMAX and DVB-S2. The application domain is the so called outer receiver, which comprises the channel coding, interleaving stages, modulator, and multiple antenna transmission. Throughout the book, the focus is on advanced algorithms that are actually in use
in modern communications systems. Their basic principles are always derived with a focus on the resulting communications and implementation performance.  As a result, this book serves as a valuable reference for two, typically disparate audiences in communication systems and hardware design.
Architectures for Baseband Signal Processing.pdf (10.63 MB , 下载次数: 1725 )
恭喜娜姐躲过赛点啊,如果娜姐赢了再发一本
发表于 2014-1-17 13:16:55 | 显示全部楼层
非常感谢提供!
发表于 2014-1-17 13:46:32 | 显示全部楼层
希望楼主多多发书。
发表于 2014-1-17 15:33:39 | 显示全部楼层
关于基带的啊,哈哈,谢谢楼主!
发表于 2014-1-17 19:00:47 | 显示全部楼层
look look!
发表于 2014-1-17 20:01:41 | 显示全部楼层
看看先
发表于 2014-1-17 20:43:35 | 显示全部楼层
yiding
发表于 2014-1-18 00:35:28 | 显示全部楼层
感謝.
发表于 2014-1-18 05:56:40 | 显示全部楼层
这个版块看这本的估计不对,不过还是顶
发表于 2014-1-18 09:58:06 | 显示全部楼层
thx for sharing~
GMT+8, 2025-12-18 03:35 , Processed in 0.025272 second(s), 7 queries , Gzip On, Redis On.
