查看: 4445|回复: 2
[求助] tcl中如何跨行匹配
发表于 2014-1-16 17:00:11 | 显示全部楼层 |阅读模式
tcl中如何跨行匹配, 求正则表达,谢谢!
发表于 2014-1-16 21:39:56 | 显示全部楼层
试试看这个:
regexp
-line
Enables newline-sensitive matching. By default, newline is a completely ordinary character with no special meaning. With this flag, “[^” bracket expressions and “.” never match newline, “^” matches an empty string after any newline in addition to its normal function, and “$” matches an empty string before any newline in addition to its normal function. This flag is equivalent to specifying both -linestop and -lineanchor, or the (?n) embedded option (see the re_syntax manual page).
 楼主| 发表于 2014-1-20 18:15:40 | 显示全部楼层
回复 2# sjtusonic
    Hi, 版主:
    regexp -line应该只对单行进行操作,属于行敏感,
    我如果在多行匹配,应该用 -inline, 我已经尝试过并且解决了, 谢谢!
GMT+8, 2025-9-17 03:50 , Processed in 0.014349 second(s), 5 queries , Gzip On, Redis On.
