查看: 2805|回复: 5
[招聘] 美资公司武汉分公司招聘模拟版图设计工程师
发表于 2014-1-13 21:35:16 | 显示全部楼层 |阅读模式
美资公司武汉分公司招聘模拟版图设计工程师, 三年以上模拟版图设计经验。
Requirements:
You must be experienced with physical layout and verification tools such as Virtuso , Laker, Calibre, Hercules.
You need have layout design experience for advanced process node like 40nm, 28nm.
You also need to have experience at least one of the following key functions: PLLs, High speed transmitters and receivers, High speed ADC, DAC and Bandgaps.
Familiar with Unix and Windows operating system for script writing or post-processing.
Have excellent interpersonal and communication skills.
Generally, this position requires Bachelor or above degree, at least 3+ years related working experience. The successful candidate must possess a solid understanding of specialization area plus working knowledge of one other related area. Can resolves issues in creative ways. Exercises judgment in selecting methods and techniques to obtain solutions. Execute projects from start to completion. Contributes to moderately complex aspects of a project. Receives little instructions on day-to-day work, general instructions on new assignments and projects. Determines and develops recommendations to solutions. Work is evaluated upon completion to ensure objectives have been met. Works on team-driven or task-oriented projects. May guide more junior peers with aspects of their job. Networks with senior internal and external personnel in own area of expertise.
联系 QQ 30892354 请注明 应聘版图设计工程师
发表于 2014-1-14 14:43:50 | 显示全部楼层
如果没有猜错的话,应该是凹凸。。。。。。
发表于 2014-1-14 16:15:13 | 显示全部楼层
回复 2# silverpuma
   这公司不是不行了吗
发表于 2014-1-15 13:15:02 | 显示全部楼层
物是人非啊
 楼主| 发表于 2014-1-16 23:13:04 | 显示全部楼层
不是凹凸
发表于 2014-1-17 09:14:54 | 显示全部楼层
实际上是世界最大的EDA Tool Vendor  和 SerDes IP 最大的Vendor
应该猜到了
GMT+8, 2025-12-23 09:57 , Processed in 0.035226 second(s), 6 queries , Gzip On, Redis On.
