楼主: knight1978
[原创] DSP经典C语言程序库-非常有用
发表于 2011-12-13 17:05:11 | 显示全部楼层
sptest.c
/*                             SPTEST.FOR                               */
/*             SIGNAL PROCESSING ALGORITHMS SUBPROGRAM TESTS            */
/*                       Source code in C                               */
/* This program tests the subroutines and functions in SIGNAL PROCESSING */
/*  ALGORITHMS, Appendix A1.  In each test the message "passed" or */
/*  "failed" is printed after the name of the routine by the spout */
/*  subroutine at the end of this program. */
/* Each test checks for correct performance for a specific input, not for */
/*  all inputs, so the test is a check rather than a guarantee that the */
/*  routine is working correctly. */
/* A performance factor, Q, is computed as a function of the subroutine */
/*  output and compared with its correct value in the "spout" */
/*  statement.  For example, the correct value of Q in the test of the */
/*  SPFFTR subroutine is 8389.506.  A check sum of the data arrays in this */
/*  program is also computed, to assure that they remain intact. */
/* If a test fails, check the listings of both the subroutine and this */
/*  program against those in Appendix B1 of SIGNAL PROCESSING ALGORITHMS. */
/*  If the listings agree, make sure your compiler meets the C */
/*  standard.  Next, try printing the float value of Q for this test. */
/*  There may be a roundoff error.  If all else fails to yield a reason */
/*  for the failure, call John M.A. Salas at a reasonable hour. */
发表于 2016-9-24 23:05:41 | 显示全部楼层
没有使用说明,函数也比较少。
发表于 2016-10-17 14:22:45 | 显示全部楼层
xuexixuexi
发表于 2016-11-5 13:58:01 | 显示全部楼层
谢谢分享,必须赞一个~
发表于 2019-10-17 17:19:02 | 显示全部楼层
好书。。。
好书。。。。
发表于 2019-10-17 17:55:42 | 显示全部楼层
谢谢分享。。。
谢谢分享。。。。
发表于 2019-11-28 08:43:39 | 显示全部楼层
围观一下
发表于 2019-11-28 10:37:56 | 显示全部楼层
好东西 谢谢分享
GMT+8, 2025-11-26 10:01 , Processed in 0.015944 second(s), 3 queries , Gzip On, Redis On.
