楼主: lingzhi
紧缺的hspice200603 win版本大放送
发表于 2007-6-5 02:35:15 | 显示全部楼层
lingzhi:
according to your result, everything's clear:
the job is concluded, but nothing had actually run: take a look at the warnings in your DEMO.TXT, all the tokens related to RF sims are crossed-out or "unreconisable" as the polite output file shows below. I run the same gpsvco.sp with hspice.exe (NOT hspicerf.exe), and it gives exactly the same result.  I guess you have probably mistaken hspice.exe as hspicerf.exe ....
==> attached below is part of your DEMO.TXT  <==
* transient analysis test bench
* stimulate oscillation with 2ma pulse
*iosc ip in pulse ( 0 2m .01n .01n .01n 10n 1u )
*.probe tran v(ip) v(in)
*.print tran v(ip) v(in)
*.tran .01n 10n
* harmonic balance test bench
.sweepblock vtune_sweep
+ 0 5 0.2
+ 2 3 0.1
**warning**  unrecognizable command card
.hbosc tones=1550e6 nharms=12
+ probenode=ip,qn,4
+ sweep vtune sweepblock=vtune_sweep
.phasenoise dec 10 100 1e7
.print phasenoise phnz
**warning**  could not identify variable type phasenoi
**warning**  unrecognized output variable=phnz     on above line
.probe phasenoise phnz
.print hb v(ip,in) v(ip,in)[1] v(qp,qn) v(qp,qn)[1]
.probe hb v(ip,in) v(ip,in)[1] v(qp,qn) v(qp,qn)[1]
.probe hb hertz[1][1]
* nmos device from mosis 0.35um process
* bsim3 version 3.1 parameters
* date: mar  8/00
* lot: n9co                  waf: 07
* temperature_parameters=default
**warning**  could not identify variable type hertz[1]
**warning**  unrecognized output variable=hertz[1] on above line
 楼主| 发表于 2007-6-5 09:19:00 | 显示全部楼层
现在上传的是用HSPICERF Y-2006.03-SP1 run  gpsvco demo的输出文件
请各位查看 license用的是200609的
gpsvco.rar
103.61 KB, 下载次数: 18 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-6-5 09:26:30 | 显示全部楼层
我觉得200603可以
但200703不行
 楼主| 发表于 2007-6-5 09:51:52 | 显示全部楼层
rf,在demo中选择了几个例子run后的结果文件
demo.rar
441.54 KB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-5 20:04:24 | 显示全部楼层
______
______
______
[ 本帖最后由 wchen014 于 2007-6-5 20:13 编辑 ]
发表于 2007-6-5 20:12:07 | 显示全部楼层
Thank you lingzhi
Your updated results seem'd fine to me and did its job very well
It must be my settings i have to figure out a way to fix... I'll give a tutorial once i got clear..
发表于 2007-6-19 10:10:49 | 显示全部楼层
十分需要的东西,强烈支持
头像被屏蔽
发表于 2007-6-20 22:28:42 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2007-6-20 23:05:40 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2007-6-20 23:18:52 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-23 10:14 , Processed in 0.042025 second(s), 7 queries , Gzip On, Redis On.
