查看: 2884|回复: 4
[求助] 如何查看某个attribute的涵义
发表于 2013-12-18 20:53:42 | 显示全部楼层 |阅读模式
ICC中,如何查看某个attribute的涵义?比如cell的attribute有一个是is_soft_fixed,设成true/false有何作用?
发表于 2013-12-19 09:20:05 | 显示全部楼层
refer to the userguide please!
for exaplme you  can get the iformation for is_soft_fixed:
Attribute              Coarse placement             Detail placement           Optimization
is_soft_fixed        Cannot move cells             No restrictions              No restrictions
 楼主| 发表于 2013-12-19 10:18:48 | 显示全部楼层
回复 2# yahemao123
   Could you tell which UserGuide I should refer to? I cannot find it anywhere.   BTW, can I refer it in icc_shell with any command like "man" or "help"?
   Thanks very much!
发表于 2013-12-19 11:22:22 | 显示全部楼层
I have got a file named ICC-UserGuide in company's computer!
but I can't upload it or get it out.
I have never done those things as your describing!
发表于 2014-5-14 08:15:16 | 显示全部楼层
icc文档里面有, iccug.pdf吧,
GMT+8, 2025-12-30 09:36 , Processed in 0.027426 second(s), 6 queries , Gzip On, Redis On.
