查看: 2700|回复: 2
[招聘] 美光半导体技术-IC Layout Design Engineer
发表于 2013-12-18 18:32:00 | 显示全部楼层 |阅读模式
Dear All,
Micron is now looking for IC Layout Engineer. More than 3 years working experience in IC Layout will be much preferred.
Those who are interested in this position, please kindly contact Ella Wang via ellawang@micron.com
P.S. this position will be locate in Shanghai
Here I attached the JD below for your reference.
IC Layout Design Engineer半导体集成电路版图设计工程师
Description
As an IC Layout Design Engineer at Micron's Shanghai Design Center, you will work in a highly innovative and motivated design team using state of the art memory technologies to advance DRAM Memory design. As part of a multi-disciplinary team, you will contribute to physical layout floorplan of various memory chip circuit blocks, and perform block level layout, LVS/DRC verification and using other CAD tools to check layout. Of course you will also work closely with Micron's various design teams in US and other countries and leverage vast resources available through out Microns global sites. Additionally, you will perform verification (LVS/DRC etc) of layout to the full-chip level, and assist in project tapeout.
Requirement
-College degree (or above) in Electrical Engineering or other related engineering field.
-2+ years of IC custom layout working experience (more experienced engineers highly welcome).
-Proficiency with Cadence OA and Calibre verification tools desirable.
-Understanding of basic CMOS circuits is a plus.
-Understanding of DRAM/Flash architecture or previous memory layout experience is a plus.
-English language skill in writing and speaking is a plus.
-No fresh graduates will be considered.
Education
 楼主| 发表于 2013-12-18 18:38:30 | 显示全部楼层
忘记说了,PCB layout不合适此职位,谢谢
 楼主| 发表于 2013-12-25 10:48:09 | 显示全部楼层
没有人有兴趣吗?
GMT+8, 2025-12-25 00:34 , Processed in 0.015477 second(s), 4 queries , Gzip On, Redis On.
