查看: 1967|回复: 0
[招聘] NO.73-Principal AMS Physical design engineer(Shanghai)
发表于 2013-12-4 16:08:06 | 显示全部楼层 |阅读模式
Skillful capable of physical design of Analog and mixed signal area: Matching sense from transistor, Resistor and capacitor, Power and Ground coupling, Signal path from Differential pairs, etc, if knowledge on digital blocks P&R prefered.
•In-depth knowledge and hands-on experience on AMS CAD support, such as write Scrips to support PDK(pcell, call back), ams back-end stuffs, including Skill language, Perl, verification runset improvement etc
&#8226roficient with xx layout tools specifically Virtuoso XL and Assura (xx 6.1 experience a plus)
•Experience in 65 nm and below analog CMOS layout, verification (DRC, LVS), and top integrated tapeout to foundry
•Ability to coordinate with the other analog IC circuit layout,  ensuring robust, efficient, consistent and successful delivery of analog IC circuit layout.
•Fundamental understanding of IC design technology and process/methodology
•Skilled in Analog IC top level chip assembly including floorplanning and block layout
•Dedicated experience on key macros is prefered: SerDes, High speed/high resolution Data Converters; High Speed PLL's; Low Noise Design;
•Hands-on experience conducting DRC/LVS analysis and recommending appropriate solutions
•Solid understanding of IC design technology and process/methodology in AMS layout
Position Requirements:
BSEE degree with >6+ years of applicable experience in advanced analog and mixed signal design industry. Essential that the individual demonstrates strong communication, verbal and written, and project management skills. Requires very good communication skills in English and Chinese.
Company Info Type:
Global Default
Company Information:
xx is the global leader in software, hardware, and silicon IPs that is driving the transformation of the electronic design automation (EDA) industry. This application-driven approach for creating, integrating, and optimizing designs helps customers realize Analog & Digital ICs , System-On-Chip devices, IP and complete systems at lower costs and with higher quality.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-26 20:16 , Processed in 1.519301 second(s), 5 queries , Gzip On, Redis On.
