查看: 3717|回复: 5
[求助] uvm1.1 使用VCS验证,如何设置
发表于 2013-11-25 15:08:31 | 显示全部楼层 |阅读模式
求助:
各位前辈,大侠,我是个UVM初学,最近在这里下了个UVM1.1的LAB,想用来学习UVM,但是把文件解压之后在.cshrc下设置了环境变量指向其bin目录。
但是后面有安装覆盖文件和编译就不知道应该怎么按照VCS版本配置了,我用的VCS是 VCS-MX E-2011.03-SP1
希望能有前辈出来指点下,不胜感激!!!
 楼主| 发表于 2013-11-25 15:09:05 | 显示全部楼层
自己顶下,真的很急
发表于 2013-11-25 18:46:21 | 显示全部楼层
很简单吧,按照readme,把软件配置好,就可以跑了吧。。。。
 楼主| 发表于 2013-11-25 19:26:12 | 显示全部楼层
    readme 我也看了就是下面这个不太懂的,谢谢能具体指点下么
You must then obtain from your SystemVerilog tool vendor a tool-specific
distribution overlay. That overlay may be specific to the machine
architecture and/or operating system you are using. Make sure you provide
the output of the '$UVM_HOME/bin/uvm_os_name' script as well as the version
of the simulator you are using when requesting a UVM overlay from your vendor.
            % $UVM_HOME/bin/uvm_os_name
   IUS:     % irun -version
   Questa:  % vlog -version
   VCS:     % vcs -ID
Follow the installation instructions provided by your tool vendor for
installing the overlay in your UVM installation.
Note to EDA vendors: to support multiple tool-specific overlays in the
same UVM distribution, please locate any tool-specific files in a
tool-specific sub-directory.
 楼主| 发表于 2013-11-25 19:28:29 | 显示全部楼层
回复 3# A1985
    readme 我也看了,请宁能具体指点下怎么配置么,十分感谢!!!
发表于 2013-11-25 22:22:46 | 显示全部楼层
这个是看你eda工具能支持的uvm自带的版本,当然你可以自己编译新的uvm。看工具手册吧,ius简单点,直接irun -uvm ....
GMT+8, 2025-12-24 20:36 , Processed in 1.368533 second(s), 5 queries , Gzip On, Redis On.
