查看: 1291|回复: 0
[ARM] 防止时钟分布电路中 EMI 的应用手册
发表于 2013-11-19 00:01:14 | 显示全部楼层 |阅读模式
EMI Prevention in
Clock-Distribution Circuits
SCAA031  [url]http://0734hunjia.com/[/url]
2
IMPORTANT NOTICE
Texas Instruments (TI) reserves the right to make changes to its products or to discontinue
any semiconductor product or service without notice, and advises its customers to obtain the
latest version of relevant information to verify, before placing orders, that the information being
relied on is current.
TI warrants performance of its semiconductor products and related software to the
specifications applicable at the time of sale in accordance with TI’s standard warranty. Testing
and other quality control techniques are utilized to the extent TI deems necessary to support
this warranty. Specific testing of all parameters of each device is not necessarily performed,
except those mandated by government requirements.
Certain applications using semiconductor products may involve potential risks of death,
personal injury, or severe property or environmental damage (“Critical Applications”).
TI SEMICONDUCTOR PRODUCTS ARE NOT DESIGNED, INTENDED, AUTHORIZED,
OR WARRANTED TO BE SUITABLE FOR USE IN LIFE-SUPPORT APPLICATIONS,
DEVICES OR SYSTEMS OR OTHER CRITICAL APPLICATIONS.
Inclusion of TI products in such applications is understood to be fully at the risk of the
customer. Use of TI products in such applications requires the written approval of an
appropriate TI officer. Questions concerning potential risk applications should be directed to
TI through a local SC sales office.
In order to minimize risks associated with the customer’s applications, adequate design and
operating safeguards should be provided by the customer to minimize inherent or procedural
hazards.
TI assumes no liability for applications assistance, customer product design, software
performance, or infringement of patents or services described herein. Nor does TI warrant or
represent that any license, either express or implied, is granted under any patent right,
copyright, mask work right, or other intellectual property right of TI covering or relating to any
combination, machine, or process in which such semiconductor products or services might
be or are used.
Copyright
1994, Texas Instruments Incorporated
i
Contents
Title        Page
Introduction
1
Higher Harmonic Components of Digital Waveforms        1
Transmission Line and Radiated Emissions        4
The Antenna Effect
7
Spectrum Analyzer Results
7
Effects of Impedance Matching
9
Summary of Methods for EMI Prevention        12
Characteristic Impedance of the Transmission Line        12
PCB Shielding Effects
12
Impedance Matching
12
Conclusion
12
Acknowledgment
12
List of Illustrations
Figure        Title        Page
1      Triangle Wave
1
2      Spectrum Envelope for Triangle Wave of Figure 1        1
3      Square Wave
2
4      Spectrum Envelope for Square Wave Shown in Figure 3        2
5      Square Wave, Duty Cycle = 50%
3
6      Spectrum Envelope for Square Wave Shown in Figure 5        3
7      Square Wave, Duty Cycle = 50%
3
8      Spectrum Envelope for Square Wave Shown in Figure 7        3
9      Transmission Line With a Driver and a Receiver        4
10     Transmission Line With a Termination Resistor Value Less than Z
o
5
11     Impedance Matching Through a Pulldown Resistor        6
12     Impedance Matching Through Parallel Resistors (Thevenin’s Termination)        6
13     Impedance Matching Through a Damping Resistor        6
14     Antenna Effect of Transmission Lines        7
15     Block Diagram of Test Setup for Measuring Radiated Emissions        7
16     Emission Level vs Frequency
8
17     Test Setup With Unterminated Transmission Lines        9
18     Test Setup With 56-
Ω
Damping Resistor Terminations        9
19     EMI Evaluation Results (Device Under Test = CDC208)        10
20     EMI Evaluation Results (Device Under Test = CDC204)        11
21     EMI Evaluation Results (Device Under Test = ABT240)        11
22     EMI Evaluation Results (Device Under Test = CDC303)        12
GMT+8, 2025-12-23 02:51 , Processed in 0.015971 second(s), 5 queries , Gzip On, Redis On.
