查看: 2415|回复: 2
装 ic5141 usr6 刚开始装这样说是什么意思?
发表于 2013-11-2 02:47:48 | 显示全部楼层 |阅读模式
Executing control programs (pre-load) ...
sort: open failed: +3: No such file or directory
expr: syntax error
SL-8: No information available on :.
Call the Cadence Customer Response Center (CRC) at 1-800-Cadenc2
(1-800-223-3622) to get the right /cadence/ic5141usr6/install/tmp/mediaMap.lnx86 file.
发表于 2013-11-2 14:00:13 | 显示全部楼层
需要 bash支持?
发表于 2017-11-15 17:24:55 | 显示全部楼层
增加到~/.bashrc:
export _POSIX2_VERSION=199209
GMT+8, 2025-12-26 21:00 , Processed in 0.018194 second(s), 7 queries , Gzip On, Redis On.
