查看: 11342|回复: 32
[资料] Transients of Modern Power Electronics
发表于 2013-10-22 11:33:37 | 显示全部楼层 |阅读模式
In the mainstream of power electronics developments, critical transient processes a re ignored and analysis
methods are limited to averaged, steady state behavior. Topology, efficiency, total harmonic distortion, and output voltage ripples are often addressed and the voltage spike, in-rush current, minimum pulse width, and so on, are ignored
http://www.amazon.com/Transients-Modern-Power-Electronics-Hua/dp/0470686642/ref=sr_1_1?ie=UTF8&qid=1382412711&sr=8-1&keywords=Transients+of+Modern+Power+Electronics
0470686642Electronics.zip
5.14 MB, 下载次数: 314 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2013-10-24 15:56:29 | 显示全部楼层
3333333333ks!;
发表于 2013-10-29 17:32:11 | 显示全部楼层
真感谢分享。
发表于 2013-11-10 23:09:22 | 显示全部楼层
不錯的好書當然不能錯過囉,謝謝分享。
发表于 2013-11-13 22:42:44 | 显示全部楼层
謝謝分享.
发表于 2013-11-16 09:46:44 | 显示全部楼层
Good sharing!!!
发表于 2014-8-6 16:20:48 | 显示全部楼层
The subharmonic pole peaking is akin to the double-pole response of an LC filter. So it, too,
has a certain “Q”, which depends on the slopes of the inductor current, and the applied slope
compensation. If the applied slope compensation is too low, the Q will increase, unless we
increase the inductance (to decrease the slopes of the inductor current correspondingly).
In effect, this means we need a certain minimum inductance for a given slope compensation,
to remain stable. Alternatively, we need a minimum slope compensation for a given
inductance, to remain stable. However, slope compensation, the way it is commonly applied,
affects the peak current limit too, and that can affect the output power capability of the
converter.
发表于 2014-8-6 16:21:13 | 显示全部楼层
Good sharing!!!
发表于 2015-5-9 00:11:31 | 显示全部楼层
发表于 2015-5-10 22:42:50 | 显示全部楼层
回复 1# flingcloud
GMT+8, 2025-9-17 03:32 , Processed in 0.018438 second(s), 4 queries , Gzip On, Redis On.
