查看: 2816|回复: 6
AMS混合仿真irun出错
发表于 2013-10-18 15:47:59 | 显示全部楼层 |阅读模式
AMS仿真,工具是irun,跑仿真的时候出错,请问是怎么回事??
ERROR(185) : Failed to create the netlist because either the irun executable is not in a directory listed in the 'path' variable or you are running IUS 8.1 in an unsupported platform. Correct the value of the 'path' variable or move to a supported platform and then try again.
发表于 2013-10-19 12:12:04 | 显示全部楼层
can not find irun in the 'path' list ?
 楼主| 发表于 2013-10-21 13:38:04 | 显示全部楼层
回复 2# phoenixson
Use command "which irun" can find it, but what is the 'path' list?
发表于 2013-10-22 09:30:44 | 显示全部楼层
maybe, it can not be supports in your current platform.
 楼主| 发表于 2013-10-22 10:03:54 | 显示全部楼层
回复 4# phoenixson
Thank you for your help? How can i know which plantform I have been used??
发表于 2013-10-23 09:52:33 | 显示全部楼层
回复 5# tangyaoyun
   execute the command 'uname -a' ,you will see the machine version and linux release, or you can execute 'lsb_release -a' to check the release version.
发表于 2014-2-17 22:29:58 | 显示全部楼层
diing
GMT+8, 2025-12-21 01:59 , Processed in 0.020539 second(s), 6 queries , Gzip On, Redis On.
