查看: 4072|回复: 8
[资料] Studies on Via Coupling
发表于 2013-10-11 15:09:06 | 显示全部楼层 |阅读模式
Studies on Via Coupling on Multilayer Printed Circuit Boards.pdf (2.02 MB , 下载次数: 94 )
Chapter 1 Introduction.pdf (45.55 KB , 下载次数: 33 )
Chapter 2 Resonant cavities and via coupling inside multilayer PCB\'s.pdf (110.71 KB , 下载次数: 51 )
Chapter 3 Descriptions of the structures to be studied.pdf (246.96 KB , 下载次数: 47 )
Chapter 4 Modelling.pdf (437.81 KB , 下载次数: 56 )
Chapter 5 Measured results.pdf (470.29 KB , 下载次数: 51 )
Chapter 6 Discussion.pdf (60.65 KB , 下载次数: 25 )
Chapter 7 Conclusions & References.pdf (40.79 KB , 下载次数: 29 )
Chapter 1 Introduction.pdf (45.55 KB , 下载次数: 17 )
Chapter 2 Resonant cavities and via coupling inside multilayer PCB\'s.pdf (110.71 KB , 下载次数: 23 )
Chapter 3 Descriptions of the structures to be studied.pdf (246.96 KB , 下载次数: 36 )
Chapter 4 Modelling.pdf (437.81 KB , 下载次数: 34 )
Chapter 5 Measured results.pdf (470.29 KB , 下载次数: 36 )
Chapter 6 Discussion.pdf (60.65 KB , 下载次数: 17 )
Chapter 7 Conclusions & References.pdf (40.79 KB , 下载次数: 16 )
Contents.pdf (435.28 KB , 下载次数: 44 )
Studies on Via Coupling on Multilayer Printed Circuit Boards.pdf (2.02 MB , 下载次数: 63 )
发表于 2013-10-13 04:53:28 | 显示全部楼层
楼主辛苦了。应该是最后一个文件就够了吧。
发表于 2013-11-29 15:19:55 | 显示全部楼层
回复 1# hungkuochiang
    弄成一个文件多厚道!
发表于 2013-12-25 14:28:36 | 显示全部楼层
RE: Studies on Via Coupling [
发表于 2014-1-14 14:46:11 | 显示全部楼层
发表于 2014-2-18 06:38:32 | 显示全部楼层
下来看看是哪个同行的
发表于 2014-2-18 06:42:37 | 显示全部楼层
这个也太老了。
发表于 2014-3-4 05:08:24 | 显示全部楼层
Good job!
发表于 2019-7-3 15:00:00 | 显示全部楼层
Thanks for your sharing
GMT+8, 2025-9-15 05:18 , Processed in 0.017397 second(s), 4 queries , Gzip On, Redis On.
