楼主: JoyShockley
[原创] 教你如何直观推导两级ota的次主极点的位置——from JoyShockely
发表于 2013-10-19 06:18:59 | 显示全部楼层
回复 30# liuqilong8819
    读书要先读厚再读薄,所以执果索因不仅没有错,反而是应该倡导的,只不过楼主读的还不够。
发表于 2013-10-24 12:45:08 | 显示全部楼层
回复 29# feynmancgz
are you kidding me?
For example, you design a product of two stages op-amp. Can you ask the customer not put a large cap in the load? Load side is decided by the customer. what you can design is the internal op-amp.
发表于 2013-10-24 13:13:07 | 显示全部楼层
回复 32# Evanpeng
    你说的不全对吧。TI/ADI 的运放,都会说最大电容能多少。我曾经看到过当负载电容太大的时候,adi 的运放震起来了
发表于 2013-10-24 13:54:06 | 显示全部楼层
我倒是觉得这种分析方法其实蛮有用的
看到一个电路,直接看到的就是各种电容和电阻
可以头脑里面进行扫频,AC分析
其实多看看多级运放的传函分析的话,自然就会形成这种思考方法
发表于 2013-10-24 14:04:29 | 显示全部楼层
回复 32# Evanpeng
   Are you kidding me? I am talking about teaching in a class. You are talking about design a product.
发表于 2013-10-24 14:13:30 | 显示全部楼层
回复 32# Evanpeng
   Another funny thing is that if your customer ask you to drive a large capacitor, you will choose this topology ?
   So funny......
发表于 2013-10-25 00:19:06 | 显示全部楼层
回复 36# feynmancgz
Do you have ever deal with customer? Which high volume product you design?
You even don't understand what I am talking about.
Normally, the product will ask maximum cap value. sometimes, the load the cap will be larger than miller cap. since gm*ro=10 under sub-micro process. you can not afford too large Cc.
发表于 2013-10-25 00:22:47 | 显示全部楼层
回复 37# Evanpeng
    如果客户要求的范围太大,不就是换一种设计么?  再说了又不是所有的运放都是用来驱动板子上的电容。不用把产品设计和教室里面上的混在一起
发表于 2013-10-25 01:20:48 | 显示全部楼层
回复 37# Evanpeng
   Too funny........Teaching is teaching, designing products is designing products.
   Why do you always mix them up ?
   Seems you know much about designing products.....actually you know nothing, just showing off......
发表于 2013-10-25 04:03:38 | 显示全部楼层
别太迷信"直观为王". 推倒熟练了, 自然可以看出零极点位置. 拔苗助长, 得不偿失.
GMT+8, 2025-10-17 08:29 , Processed in 0.017609 second(s), 3 queries , Gzip On, Redis On.
