查看: 4087|回复: 0
[招聘] 能去新加坡的数模混合专家还有数字职位
发表于 2013-9-17 10:42:36 | 显示全部楼层 |阅读模式
能去新加坡的ic职位
所有候选人都要英文口语比较好,因为面试和以后工作都需要与新加坡那边打交道,并且会派到新加坡工作一段时间(如果表现很好,可以帮他申请新加坡永久居留)
Qq: 983144394
Email:
ic@hi-talent.net
Analog/Mixed-Signal IC Design Expert
Description
In this position, you will be a part of the Analog/Mixed-Signal Design team working on the development of state of the art CMOS circuit designs for high speed, low noise and low power requirements. As an expert for analog IC design in the team, you will be required to assume a technical leadership role in the development of analog/mixed-signal macros for system applications DSL, WLAN, Ethernet or high-speed optic interface.
You will drive concept design of analog circuits in nm-CMOS technologies, run the implementation and verification, cooperate with the layout team and contribute to laboratory measurement techniques.
  • Enhanced experience in CMOS analog/mixed-signal design
  • (e.g. PGA, Filter, ADC, DAC, BGP, LDO, … )
  • Drive concept development, topology analysis and modeling of CMOS analog circuits
  • Good know-how of CMOS deep-submicron device parameters and layout dependent effects
  • Experience in laboratory measurement techniques of analog/mixed-signal modules
  • Good knowledge of UNIX, Cadence Virtuoso/Spectre, Spice, Matlab and MS-Office
  • Stress resistant and flexible
Requirements
  • Degree in electrical engineering or communication technology (university or university of applied sciences)
  • Professional experience more than 9 years
Embedded System Engineers
Responsibilities
Linux Driver/Kernel development for Ethernet/DSL/LTE Modem/Router/Home Gateway
Heavy involvement in pre silicon software/firmware/hardware emulation and co-verification
System bring up and validation; software integration and qualification
Active participation as Key customer expert support/Linux driver porting and kernel migration/software concept profiling
Requirements
University degree of computer science or electric engineering
Minimum two years' experience of embedded software development
Familiar in Linux driver and kernel architecture.
Rich experience in Linux kernel/driver development and master the Linux kernel/driver debugger skill
Knowledge of XDSL, ETHERNET switch, wireless LAN, Security Engine and microprocessor is an advantage
Knowledge of Mercurial/perforce or other version control tools is preferred
A Team player; very proactive and self-motivated
Design and Verification
Responsibility
  • Break down of system/chip specification to a digital concept considering feasibility of implementation and verification in close partnership with concept engineering
  • Interfacing with physical design team
  • Digital design (RTL/VHDL coding) taking into account given timing, area, and power targets
  • Development and implementation of algorithms enabling new features
  • Development of testbenches
  • Definition and execution of block- and chiplevel pre-silicon verification plans by using state-of-the-art verification methodologies
  • Support in debugging and analysis of chips in lab
Requirement
  • Experience in programming in C, C++, System Verilog and scripting languages (Tcl, Perl) is highly desirable
  • Main focus on Telecommunication Engineering desired
  • Master degree in Electrical Engineering or Information Technology required
  • Experience / Knowledge in Keywords
  • Self motivated with excellent communications skills; willing to take ownership and responsibility
  • Strong ability to work in international teams and projects
  • Experience in clock (re)-generation and distribution in SoCs would be beneficial
  • Wide experience in telecommunication chip architecture, digital circuit design and verification
  • Proficient in digital design methodologies (VHDL/Verilog; functional, formal and timing verification (STA); synthesis)
GMT+8, 2025-12-23 22:44 , Processed in 0.031937 second(s), 6 queries , Gzip On, Redis On.
