查看: 2471|回复: 0
[招聘] 验证职位爆棚简历发ic@hi-talent.net
发表于 2013-9-10 09:55:13 | 显示全部楼层 |阅读模式
以下4个职位,C Model Developer; FPGA & System;MCU design & verification; Verification
简历发ic@hi-talent.net;QQ: 983144394
验证职位爆棚了,design, C model,MCU,FPGA,System,verification
1. C Model Developer
Position description:
This person will work with RTL, verification and firmware engineers to develop cycle precision C model of design modules. His responsibility includes:
l   Understand design specification
l   Discuss design details with RTL designer
l   Develop and verify cycle precision C model
l   Provide support to verification and firmware engineer
Qualification:
l   新毕业的硕士生或者1年工作经验的本科生,majored in EE
l   Experience in RTL design project
l   Familiar to verilog and C++
l   Experience in micro controller design is a plus
2. FPGA  & System Engineer
The person will be responsible for:
l   Design and integrate an AXI/AHB based system including host processor, DDR controller, SD/MMC, Display I/F and other peripherals., within an IP verification platform
l   Investigate and develop related drivers for the used IP’s in the system;
l   Use ISE/Vivado/Quartus, implement the design to Altera/Xilinx FPGAs,
l   Work with SW engineer, to bring up system/OS on the FPGA prototyping board. Debug and resolve failures with Logic Analyzer and/or ChipScope/SignalTap;
Qualification:
l   2 year experiences in SOC development;
l   Solid skills in logic design with Verilog/VHDL, timing closure and analysis;
l   Familiar with FPGA implementation with ISE/Quartus and debugging;
l   Knowledge and hands-on experiences in at least 1 of the below fields are required;
n   AXI/AHB bus protocols;
n   Design or bring-up of DDR2/3 controller/PHY;
n   Display interfaces/protocols such as LVDS/HDMI;
3. MCU design  and verification
The person will be responsible for the design and verification of micro-controller, including:
l   RTL coding;
l   Functional verification and performance tuning;
l   Synthesis and STA;
l   Develop direct tests and constraint random tests;
l   Coverage data collection and analysis;
Qualification:
l   2 year experiences in logic design, simulation synthesis and timing analysis;
l    Knowledge in RISC processor micro-architecture, familiar with associated tool-chains such as compiler, assembler, debugger etc.;
4. Verification
Job description:
The person will take part in verification of CPU/MCU, including:
l   Maintain and improve the verification environment and flow;
l   Make the verification plan and execute it with System verilog based coverage monitors/assertions;
l   Develop directed tests and constraint random tests;
Qualification:
l  2 year experience on high-level verification methodology (VMM/UVM/OVM)
l  Knowledge of micro-architecture of RISC processors
l   SystemC/SystemVerilog would be a plus;
GMT+8, 2025-12-25 12:01 , Processed in 0.023162 second(s), 6 queries , Gzip On, Redis On.
