查看: 7332|回复: 4
[原创] analoglib中的diode怎么用?
发表于 2013-8-30 14:57:13 | 显示全部楼层 |阅读模式
悬赏34资产已解决
直接仿的话,会提示" instance of diode requires a model name first"
最佳答案
查看完整内容
is Saturation current rs Ohmic resistance n Emission coefficient if = is(e^(Vf/(n*Vt)) - 1) Vt = kT/q
发表于 2013-8-30 14:57:14 | 显示全部楼层
rs      Ohmic resistance
Vt = kT/q
 楼主| 发表于 2013-8-30 15:24:51 | 显示全部楼层
回复 1# istart_2002
a. Open an empty text file and enter the following:
model myDiode diode is=1.8e-5 rs=1.43 n=1.22
b. Save the file and add it as one of the model files in ADE
c. Specify "myDiode" as the model name
按这个搞了一个模型,可以用。不知道1.8e-5、1.43、1.22分别是什么?
发表于 2024-8-24 20:07:32 | 显示全部楼层
// INSTANCE parameters
//    area = area of junction        []
//    is   = saturation current []
//    n    = emission coefficient []
//    cjo  = zero-bias junction capacitance [F]
//    m    = grading coefficient []
//    phi  = body potential [V]
//    fc   = forward bias capacitance [F]
//    tt   = transit time [s]
//    bv   = reverse breakdown voltage [V]
//    rs   = series resistance [Ohms]
//    gmin = minimal conductance [Mhos]
发表于 2024-11-8 21:03:03 | 显示全部楼层
您好,这个model文件仿真出的i-V曲线不是指数形式是线性的,请问您有遇到这个问题吗
GMT+8, 2025-9-13 04:42 , Processed in 0.013481 second(s), 4 queries , Gzip On, Redis On.
